A little hang up, bought new power steering hoses at autozone. All went together well, then noticed leak at steering unit, leaking out the top of the compression nut. Retightened it, still leaking, loosened it and retightened, still leaking. Went back to AZone and they said it was the right hose. Finally I dug out the old one from the storage building, I need the O ring style, had the wrong hose. I ordered it from 4wd hardware, holding me up for a few more days.
Another bad purchase I made when I first bought the 8 almost 2 years ago, coming back to bite me now. A passenger side floor pan from Ebay. I had never test fitted it until now, getting ready to cut the old one out. It is not even close, maybe if I cut it in half and use the halves separately, I may be able to use some of it. Very bad piece. I ordered a new floor pan this week also. There is enough work and money involved in building a rig without buying everything twice and doing twice the work trying to get subpar parts to work.
Tip of the Day: Spend a little time researching the right parts and spend a little extra money to get quality parts from reputable sellers, it will make you much happier in the long run
