lascrambler
lascrambler
- Pagosa Springs
- CO
I'm not sure if this is the correct location for this post, and I did a search for sending unit and nothing came up. With that said, what is the best replacement sending unit for a 20 gal tank. I got an OMIX-ADA 5357373L from Morris 4x4 and it looks cheeply made, all the internals are exposed. Also, the tube orientation is different, which is somewhat better than the one I pulled out. On the unit I pulled out the tubes pointed to the right when installed, on the new one is looks like they will face forward. The fuel lines run on the left side of the vehicle, so the original hoses made a 180deg turn. I can't find replacement hoses for the supply and return that have this bend so I will have to replace these with stock fuel hose. The closer the tubes are to the 10 o'clock position the beter, and it looks like I can get there with the new sending unit. Which begs another question. how much leeway do I have with clocking the sending unit? Is there a particular location the float has to go?
From the pictures I see on Google the Crown Automotive J532090 looks most like the one I pulled out. Looking for some advise from anyone who has done this before. Also is it a bad idea to reuse the strainer? I know they are not that expensive, but I forgot to order it and didn't know if it was worth the delay to get a new one.
One other thing comes to mind. Rollover check valves. Could not find replacements on Google search and though I'm not that concern about the valves themselves, I am concerned about their seals leaking as I have now distrubed them a bit removing the tank. Any suggestions?
