#1
Old 11-04-2009, 09:24 AM
patduke90's Avatar
patduke90 patduke90 is offline
Registered User
Greensboro, NC
patduke90's Gallery
No key required for ignition!?
Help, New owner here of an 81. I've had it for about a week and I'm starting to fix all of the little things that have gone bad over the years. Number one was the dimmer switch, now I'm at the ignition. As you can tell from the title, No key is required to start this vehicle. Just pull down the little key lock lever and turn away. Do I need a new ignition switch or is it an easier fix than that? Any help would be appreciated.
  #2
Old 11-05-2009, 07:37 AM
MarknessMonster MarknessMonster is offline
Grim Geeper
Carbondale, CO
Model/Year: 1981 SLR 1983 SL
Purchased: 1988
MarknessMonster's Gallery
That is a very common problem with the CJ ignition. My '81 Scrambler allows the same since about 1989. Instead of messing with the steering column, I put in a master cut-off switch and I don't have to carry keys. To properly correct the faulty ignition, the guts of the steering column are removed, and the ignition switch is replaced. I haven't done this, and have never completely torn down a column, but I've read a write-up on the required procedure in a thread on this board. Using your query, try the search feature on this site and I'll bet you'll find the thread.
__________________
1981 CJ8 Laredo: Camel Tan w/Nutmeg; 265K miles; 4.10-DL; T5; 33x9.50BFG-MT on 8" factory chrome wheels (insert smilie); 2.5"UK
1983 CJ8 Laredo: Chestnut Brown w/Nutmeg; 90K miles; 3.73-DL -SB 1pc; T176; AMC360; 33x12.50PC-MT soon to be on 8" factory chrome wheels; 4"TM; 8274SE
  #3
Old 11-05-2009, 06:50 PM
Wayne Wayne is offline
Registered User
West Coast Florida, FL
Model/Year: 1982
Purchased: 1990
Wayne's Gallery
Hello:
Did you replace your ignition?
My Jeep is the same and I am a bit nervous about trying to replace it.
__________________
  #4
Old 11-05-2009, 07:03 PM
Grim Geeper
Carbondale, CO
Purchased: 1988
Quote:
To clarify my previous message, I did not replace the ignition.
Quote:
Originally Posted by MarknessMonster View Post
...Instead of messing with the steering column, I put in a master cut-off switch...
__________________
  #5
Old 11-05-2009, 10:59 PM
CJ-8_Jim's Avatar
CJ-8_Jim CJ-8_Jim is offline
Registered User
NE, IL
Model/Year: '85 CJ8 Laredo w/MPI
CJ-8_Jim's Gallery
Replacing an ignition is not that bad. The toughest part IIRC (it was 7 years ago that I did mine as a new owner with nothing more than a Chilton's manual) was removing the steering wheel, (get a free puller rental from Autozone).
This is definitely something you want to do as a new owner. Why? Because it builds the confidence to doing more complex repairs later as you get to know your new toy.
__________________
1985 CJ-8 Laredo
Becoming a little less stock (4.0 head, MPI, D44 rear, stereo)
  #6
Old 11-13-2009, 07:02 PM
JEEPTHRILLS's Avatar
JEEPTHRILLS JEEPTHRILLS is offline
Registered User
Flag, AZ
Model/Year: 1982
Purchased: 2005
JEEPTHRILLS's Gallery
go to autozone and rent the wheel puller and a lockplate tool....even being a total noob...should take you no longer than half a day to do. The new lock cylinder should be between 15-30 bucks.
__________________
82 CJ-8: 4.2L (Weber 38/38, TFI, ELECTRIC FANS) glass T-5, stock 3.55's, 4.5" spring lift, 33" TSL's
84 CJ-7: , D-300, slowly rotting away!!
02 GC Overland: stock
  #7
Old 12-09-2009, 09:14 AM
daltonw87 daltonw87 is offline
Registered User
Central KS, KS
daltonw87's Gallery
steering columns are not hard at all. I've replaced the ignition in 2 of my jeeps and completely rebuilt one. With the right tools it only takes about 30-45 minutes. Its not a big deal at all
Reply
Thread Tools Search this Thread
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Forum Stats
Members: 13,456
Threads: 26,264
Newest Member: trainer21
Forum Partners
Latest Threads
Google Ads
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Jeep®, CJ, and the unique Jeep® Grill design are registered trademarks of the Chrysler Corporation.
CJ-8.COM and Jmediagroup.com Inc.have no affiliation with Chrysler.
Copyright © 2009 Jmediagroup.com Inc.
