#61
Old 04-15-2009, 03:24 PM
Pepper's Avatar
Pepper Pepper is offline
Registered User
Waterloo, IL
Model/Year: 1982 Scrambler
Purchased: 2007
Pepper's Gallery
It's been a while since I updated.
Working on a few things. The wheeling season last summer / fall destroyed my gas tank skid and my steering box.
I upgraded the steering box with a box from a 1999 Dodge Durango 4wd 8cylinder. $65 from a junkyard (from a car with under 60k on it). It is a bolt up but, true to MY form, it took me forever, lol. Nothing mechanical comes easy to me but I do the best to remain patient with myself.
Got it in and WOW! Great upgrade. Steering is very tight. The Durango box is supposed to provide more steering power. I won't know until I'm on the trails next to a rock.
thought it was time for the steering box skid:
It is also time for my new 14 bolt diff cover. I didn't make this but it is a thing of beauty!! 1/2" stamped plate with 1/2" strap across the middle. The welds are amazing, so much so that the paint will be clear coat and just keep the raw look without rusting, I hope.
The gas tank skid is next, them maybe a steering box brace.
  #62
Old 04-15-2009, 08:45 PM
DC CJ8 DC CJ8 is offline
Registered User
Arlington, VA
Model/Year: 1982 Trim level unk.
Purchased: 2008
DC CJ8's Gallery
great pics! but....a 1999 Dodge Durango steering box is a direct bolt in replacement? What about the belt driven pump??
Todd
__________________
'Tracers work both ways.'
US Army Infantry Manual
  #63
Old 04-15-2009, 10:05 PM
Randyzzz's Avatar
Randyzzz Randyzzz is offline
Fully Scrambled
Sisters, OR
Model/Year: 82 base w/hardtop
Purchased: 2002
Randyzzz's Gallery
Nice! Is that a Ruff Stuff cover?
Looking forward to hear how the Durango box works.
__________________
Randy S.
"It's not what you buy, it's what you build"
82 Scrambler 5.3 Vortec/4L60E/241OR/D44&HD20/4.56 locked
90 Grand Wagoneer "She's Back!" TBI350/700R4/241C
53 Ford Tudor Street RodFOR SALE
And piles and piles of parts.................
  #64
Old 04-16-2009, 06:07 AM
Bad Karma's Avatar
Bad Karma Bad Karma is offline
Captain Sarcasm
Bowmanville, ON, Ca
Model/Year: 83 CJ-7 & 83 CJ-8
Purchased: 99/08
Bad Karma's Gallery
looks like "Great Lakes Offroad" diff cover. i got those on my 60s... MMMMMMM BEEFY!!
__________________
Wounds heals... Chick dig scars...
1983 CJ-7 "Red October" (CJ-8 organ donor)
1983 CJ-8 Scrambler (in surgery)
  #65
Old 04-16-2009, 09:57 AM
Pepper's Avatar
Registered User
Waterloo, IL
Purchased: 2007
Pepper's Gallery
Quote:
Todd
This is the steering box, not the pump. No changes to the pump, it is still a belt driven pump. The supply and return lines to the pump are the same. Actually, they are exactly the same on a '69 Olds 350, too, because that is the engine that is in my rig, lol.
The diff cover is from Great Lakes Offroad, yup! It is awesome. I also have the 14 bolt pinion guard. It is made from 1/2" plate also!
  #66
Old 11-04-2009, 12:54 PM
Pepper's Avatar
Registered User
Waterloo, IL
Purchased: 2007
Pepper's Gallery
Update on the steering. Okay the Durango box is NOT a direct bolt up. The box does bolt to the frame but the input shaft on the box has a smaller diameter. It worked for a while then failed under duress, lol. After 5 trail fixes we got it on the trailer.
Solution:
Another Durango Box, then took the lower steering shaft out of a Durango and then cut both the CJ and Durango columns and combined them.
Durango on top, Jeep on bottom:
Durango on bottom:
Drilled for a plug weld, also:
Then welded it:
Tested it out wheeling at Flatnasty last weekend and it worked like a charm. A LOT more steering with the Durango box but not quite enough so . . .
More cool stuff on the way:
It was an extra $16 or so to make sure I would have it by Friday but would like to have on to test out this weekend. I have help on Friday night so wanted to make sure it was here.
Bigger items: Cylinder was only $82 and the hydraulic hoses only $10.50 each. The total, with 2 day shipping was $100 less than the trail-gear kit and about the same savings over the parts from Redneck Ram (West Texas Offroad).
My setup will be a little more booty fab but what the heck, everything else on my rig is, too, lol!
  #67
Old 11-04-2009, 01:16 PM
CJ8LVR's Avatar
CJ8LVR CJ8LVR is offline
Jake White ~SOA President
Madison, AL
Model/Year: 1982
Purchased: 1996
CJ8LVR's Gallery
Quote:
I'll have to disagree there!
Nice "adaptation". It really does look good.
I'm diggin' that diff cover too a few posts up. Where did it come from?
BTF perhaps?
__________________
1982 CJ-8
1982 SOA Charity CJ-8
1950 Willys Jeepster
Rocket City Rock Crawlers ~ Vice President
Current Scrambler Buildup Pics
If we ever forget that we are One Nation under God, then we will be a Nation gone under. - Ronald Reagan
  #68
Old 11-04-2009, 01:19 PM
Pepper's Avatar
Registered User
Waterloo, IL
Purchased: 2007
Pepper's Gallery
Great Lakes Offroad, that diff cover is a beautiful thing, lol:
http://www.greatlakeoffroad.com/diff.html
Oh, and thanks for the comments. I will post up pics and info on the hydro assist. Should have it done by Friday night. Box is already drilled and tapped. A buddy of mine is helping, he has forgotten more than I'll ever know!
  #69
Old 11-05-2009, 10:58 AM
Pepper's Avatar
Registered User
Waterloo, IL
Purchased: 2007
Pepper's Gallery
Got my gas tank skid built:
Actually had posted this up in bigred1969's post:
http://www.cj-8.com/forum/showthread...=gas+tank+skid
but wanted to keep my projects together in this thread.
I started by using some steel strap and bending in in under the gas tank and bolting in through the crossmembers to hold the gas tank in place. Sorry no pics, just bent 2" steel strap.
Then I welded an angle iron crossmember in the back of the Jeep, welded in 5 studs that drop down from the top:
As you can see I drilled out another piece of angle and slotted the holes that would mount under the skid crossmember.
Made a "frame" for the gas tank skid with angle iron by cutting and bending it, then welded the end pieces to the cross brace, basically making a skeleton for the skid.
I bolted up the skeleton in place to the frame, then cut plate for the back and bottom and tacked them into place.
With the 14 bolt, I had to notch out quite a bit so it would not have clearance issues. I braced inside the skid with some angle to give it strength. As you can see I simply bolted it into the crossmember above the rear axle.
Actually I welded studs so when I go to install it, I slip the two studs on the front (? or rear depending on your opinion of how to describe it, lol) . . . okay the end over the axle . . . sllip the studs into the hole on the crossmember and that holds that while you simple slip the other side over the studs welded into the angle with the studs, clamp it with some vice grips and its in. Put the nuts on it and it is installed. This is SO much easier to install than the one I made for the TJ!!
All in all, I'm happy with the finished product. Some of the welds got ugly 'cause there was so much to weld I know I kept bumping into the duty cycle of the welder.
Reply
Thread Tools Search this Thread
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forum Stats
Members: 12,536
Threads: 23,725
Newest Member: rubenzboiz
Forum Partners
Latest Threads
Google Ads
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Jeep®, CJ, and the unique Jeep® Grill design are registered trademarks of the Chrysler Corporation.
CJ-8.COM and Jmediagroup.com Inc.have no affiliation with Chrysler.
Copyright © 2009 Jmediagroup.com Inc.
