#1
Old 10-16-2009, 11:00 AM
barrys barrys is offline
Registered User
East Norriton, PA
Model/Year: '81 & '82
Purchased: '93
barrys's Gallery
bunch of CJ/YJ/TJ/LJ (and some ford f series parts) for sale in SE PA
These parts are my brothers, he's accumulated quite a bit of stuff and he's gonna start selling off stuff he doesn't need. LMK if you want pictures, I'll try and get them for you.
Winches
Warn 12000 pound winch, nice shape, with remote and roller fairlead, selling since I got a nice deal on a 16.5ti - $700
Dayton 6Z002 winch, 3500lbs winch - $150 (Originally bought for my trailer but found too good of a deal on an 8000lb winch to resist). This is actually a Superwinch that was rebadged by Grainger (Link to it at Grainger for specs)
Warn U2500 winch, brand new in box - $190
CJ Stuff
CJ-7 Fenders (Blue), straight, a little rust - $90
CJ-7 Fenders (maroon) straight, some surface rust- $135
CJ-7 dashpad, tan, a few cracks, back & tabs are very solid - $55
CJ-7 widetrack axles (I think 2.73 ratio by doing the turn the wheel and counting how many times the yoke spins) - $250
Axles are still under the frame, if you want the frame and axles, I'll lower the price
CJ-7 Frame, great shape - $300
CJ-7 Hood, straight, little rust around the hinges due to crappy paint job by previous owner(needs to be repainted anyway so the rust would be sanded away during paint prep) - $50
258 - low miles on rebuild, good compression, complete from carb to pan, needs new fan though(blades got a little bent when motor tilted forward after I removed the tranny) - $400
Still on the above frame but I've got an engine hoist, if you want the frame, axles and engine I'll make a good deal on it.
T-4 Transmission - $125 ($200 with bellhousing and clutch)
Rebuilt T176 transmission - $400
CJ-tailgate, white nice shape -$60
CJ-7 seat - Larado w/folding seat base, seat is bit dirty and is splitting at some of the seams, no tears though - $30
Bestop Aqua seat for CJ/YJ - Black Neoprene, Very nice shape, this is a nice seat - $175
Front Driveshaft (from CJ-7 with T4 and 258) - $50
Rear Driveshaft (from CJ-7 with T4 and 258) - $50
CJ-7 rollbar - $35
Windshield Frame with glass - some dents in the frame, good for trail use - $50
Power brake setup - $85
Factory 20 gallon plastic gas tank and skid plate - $100
Factory Laredo chrome CJ-7 grill with headlights - $50
Underdash A/C setup(couple of vents have damage) - $33
National Springs 4" lift Springs (needs centering pin on one spring and missing half of one bushing for one spring eye) - $200
Cj-7 21 gallon Gas Tank - Model: 0050 XL (more info here: http://www.justgastanks.com/store/in...roducts_id=669), just the tank and lockring, no skid plate extension or sending unit - $100
30x9.5R15 Future Enforcer M/T mud tires mounted on factory chrome CJ-7 wagon wheels(5x5.5" bolt pattern). Tires have great thread and wheels are in very nice shape - $350
35 inch x 12 inch x 15 inch Dunlop Mud Rovers on 15 x 10 Ultra 26 Aluminum wheels (5 on 5.5" CJ bolt pattern), good tread on them, no plugs or rock rash - $440
Clifford 4 Barrel intake for 258- $150
Holley 2 barrel Carb (was mounted on above intake) - $100
CJ-7/CJ-8 Windshield wiper delay module and 4 wire wiper motor (all you need to add delay wipers to your CJ) - $55
CJ-7/CJ-8 Swaybar disconnects for a 4" lift - $40
Factory CJ-7 rocker panel trim pieces. A little paint overspray on them but very nice straight shape, will need the mounting T-nut things - $60
Stainless Steel Windshield hinges, will work on CJ or YJ (no bolts included, just the hinges) - $45
Leather-wrapped CJ-7 'Oh poop' handle, tan color, decent shape, not show quality though - $40
Dana 300 Transfer Case (have 2 of them) - $150
Front turn signal markers - $5 for both
Lots of other small CJ-7 parts (parted 2 out and have a third waiting to come apart)
Non-CJ Jeep parts
TJ softtop windshield header - $20
TJ Unlimited (LJ) Bikini top (Black) - $35
Poison Spyder Custom LJ Trail Corners (new, never installed) - $100
4 Cragar 352 Street Lock wheels for sale, 16"x10", 5 on 4.5", new in box, never had tires mounted - $300
Mastercraft seat mounts for 97-02 Jeep® Wrangler TJ (both sides but missing handle thing, maybe for the seat slider? (See pic, its the thing to the left of the bolts) - $50
15 gallon gas tank skid plate, no dents, nice shape! (should also work on a CJ with a 15 gallon tank)- $30
AX-5 shifter (no shift knob) - $15
NP231 Shifter Assembly (no shift knob) -$15
YJ Factory t/c skid plate (from '90 4 cyl YJ with AX5 if that makes a difference), nice shape, no dents - $30
YJ taillights (pass side is nice, drivers side has some cracks but all one piece still) -$8
15"x7" American Racing wheels, directional style, little curb rash, 4 of them with 31" BFG ATs (tires have lots of dry rot though won't pass inspection) - $125
Non-Jeep Stuff
Warn Grilll/Brush Guard with winch mount (92+ F250), new, never even assembled -$425
Brush Guard/Winch mount (91 and earlier F250/F350), Uses Warn mounting brackets but the actual guard part is welded together. Made by a shop teacher who modeled it after a friends Warn setup - $250
White Cap from 80's or 90's full size ford (was on a 95 F250) - $100
Black Cap from 80's full size Dodge, high roof design, back window broke, I have the frame so would be easy to cut plexiglass to replace it - $100
KargoMaster Ladder Rack (2 BAR ECONO TRUCK RACKS) - Model 30040, New, never assembled Link to MFG's page - $135
Warn Front reciever hitch #38450 F250/F350/Excursion ('99 to '04), New, never installed - $150
Anderson SB-350A connectors, gray 0/2 wire, brand new - $8 each
All parts can be picked up in Linfield, PA 19468 (1 mile from the Limerick exit of Rt 422 or a couple minutes from the Philadelphia Premium Outlets) or some can be picked up during the day in Exton, PA 19341. Some things depending on the size I'll ship if you're not local as long as buyer pays shipping.
  #2
Old 10-16-2009, 12:40 PM
Jeep Addict Jeep Addict is offline
Registered User
Baton Rouge, La
Jeep Addict's Gallery
I am interested in the laredo items and the a/c set up.
Can you send some pics to tmlusco@gmail.com
  #3
Old 10-20-2009, 10:32 AM
mkzmomo's Avatar
mkzmomo mkzmomo is offline
Registered User
drummondville, qc
Model/Year: 1981
Purchased: 2009
mkzmomo's Gallery
interested with the holley carb, is it a truck avenger.... pics please saucretiz@hotmail.com
__________________
Jeep Scrambler CJ8 1981, V8, work in progress
  #4
Old 10-20-2009, 12:58 PM
bas157 bas157 is offline
Registered User
Linfield, PA
Model/Year: no scrambler, CJ-7
bas157's Gallery
Its actually a 2 barrel carb, not a 4 barrel. I have a few carbs around the house and got mixed up as to which carb came on that intake that I want to sell.
From the numbers on it, it looks to be a 350CFM 2 barrel 0-7448 model 2300
Pretty sure I've got a buyer for it though, waiting for his confirmation
(I'm the OP's brother with all the stuff for sale)
  #5
Old 10-26-2009, 12:12 PM
truckie561 truckie561 is offline
New Guy
Fort Myers, FL
Model/Year: 1982 CJ-8
Purchased: 2009
truckie561's Gallery
Maroon Fenders
I'm interested in your maroon fenders. Let me know what shipping would cost to 33901, Fort Myers FL. Thanks
  #6
Old 10-26-2009, 08:47 PM
Registered User
Linfield, PA
bas157's Gallery
Sorry, won't ship the fenders. Finding two big enough boxes to protect them during shipping would be very tough to do. It also would be kinda expensive due to the size of a box that each would fit in.
  #7
Old 11-07-2009, 08:04 AM
idiot magnet idiot magnet is offline
Registered User
indy, IN
idiot magnet's Gallery
LJ parts
Barrys,
I'm very interested in the LJ corner guards your brother has has for sale.
Please let me know if they are still available.
Thank you
  #8
Old 11-16-2009, 10:41 PM
twrandall twrandall is offline
Registered User
Riverside, CA
Model/Year: Still Looking
twrandall's Gallery
is the Tailgate straight? Is it stamped with "JEEP"?
  #9
Old 11-17-2009, 12:02 PM
JEEPTHRILLS's Avatar
JEEPTHRILLS JEEPTHRILLS is offline
Registered User
Flag, AZ
JEEPTHRILLS's Gallery
looking for clutch/brake pedal set up for CJ...prefer hydraulic clutch. and shipping 86001.
thanks
__________________
82 CJ-8: 4.2L (Weber 38/38, TFI, ELECTRIC FANS) TF999 and rust free, 4.10's with an ECTED and one piece axles, rear disks, 4.5" spring lift, 33" TSL's(shoulda gone with 35"s)
84 CJ-7: 5.9L, TF-727, D-300, slowly rotting away!!
02 GC Overland: stock
  #10
Old 11-17-2009, 10:50 PM
Registered User
Linfield, PA
bas157's Gallery
tailgate is straight and has jeep stamped into it. Does have some surface rust but is solid and has no cancer.
Clutch setup was mechanical. Are you looking for just the part that hangs on the firewall with the pedals, or are you looking for more parts?
LJ corner guards are sold to idiot magnet (shipping wednesday)
Reply
Thread Tools Search this Thread
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forum Stats
Members: 12,536
Threads: 23,724
Newest Member: rubenzboiz
Forum Partners
Latest Threads
Google Ads
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Jeep®, CJ, and the unique Jeep® Grill design are registered trademarks of the Chrysler Corporation.
CJ-8.COM and Jmediagroup.com Inc.have no affiliation with Chrysler.
Copyright © 2009 Jmediagroup.com Inc.
