02-27-2008, 10:38 PM
Registered User
1985 cj8 build
well I was crawling around my wife's new (or new to us) cj8 and I noticed that the lower shock mounts front and rear are on the spring plates. Why is this? it's a 1985 cj8! I would think the shock mounts would be the same as a cj7? I have a set of matching wide track 30front/44 rear out of a 1986 cj7 that I am going to put under the cj-8 and the lower shock mounts are welded on the axle front/rear. Is there a reason they had the lower shock mounts on the spring plates?
thanks,
7jeeps7kings
ps. sorry if this is a stupid question but cj8's are new to me!
__________________
1985 Cj8 Project!
02-27-2008, 10:45 PM
Rockville,
Model/Year: 1981-CJ-8 SL
Purchased: 2000
John N's Gallery
On the front, they should be on the axle tube; like the '86 axles.
__________________
John N....Scrambler 1981(trail), 3 Grand Cherokees 2008, 2002, 2000(street), CJ-7 (in pieces) and 2 off brand 4x4s...
02-28-2008, 12:12 AM
Registered User
Denton,
tx
Model/Year: too many to tell
Purchased: 03
tzagi's Gallery
Sounds like someone swapped in a narrow track axle........
__________________
82 scrambler...in the worx
03-01-2008, 11:57 PM
Registered User
HUmmmmm!!!
I'll have to measure the axles. I thought it seemed weird to me! But again this cj-8 stuff is new. So the lower shock mounts should be welded on the axle in the front, and the rear lower shock mount should be located on the spring plate. thanks
__________________
1985 Cj8 Project!
03-02-2008, 09:22 AM
Bi(odiesel)-curious
Quote:
Correct.
__________________
* '05 Unlimited
03-05-2008, 12:40 AM
Registered User
well!
well I must have had a blonde moment! I measured and took a better look. The front axle does have welded lower shock mounts. and the axles measure out to be 54-56" wms-wms. so they are wide tracks. I realized that I mixed up the sway bar lower mount with the shock mount! I know .... dumb@$$. anyhow thanks! next I need to pull the dif. covers off and check the gear ratio's. I'm hopping for 3.54! but I'm sure being a 4.2L engine and automatic trans it's more like 3.04 or 2.73!!
__________________
1985 Cj8 Project!
03-05-2008, 06:15 AM
Bi(odiesel)-curious
3.04 gearing wasn't used in Jeeps. My bets are on 3.31 with the 258 & TF-999 auto. Keep us posted as to what you find.
Craig
__________________
* '05 Unlimited
03-05-2008, 09:31 AM
Picture cravin' moderator
Dexter,
Model/Year: 84 Alaskan Postal
Purchased: 2002
bigwalton's Gallery
I'll bet on 2.73...
Welcome, gotta look to see where you posted the photos... you did post photos right?
__________________
'84 Alaskan Postal CJ-8: Right-hand drive, World Cab, 35s, outboarded RE 4.5" lift, XD9000i, PSC armor, Waggy 44/HD20, in the middle of a 4.0/AW4 swap
'05 Rubi LJ: Nightcrawler bumper, Ramsey 9000e, dual top, 6-speed, CB
'08 JK Unlimited: Stock, auto, hard top
My AK Postal page
Rockcrawler.com story of bringing the postal home
03-05-2008, 11:17 AM
Rockville,
Purchased: 2000
John N's Gallery
Quote:
Originally Posted by bigwalton
I'll bet on 2.73...
Ditto, it's where mine started.
__________________
03-05-2008, 11:26 AM
I'll help you out bigwalt!!
__________________
1981 Scrambler laredo w/ 97 4.0 swap. SR-4, 3in lift with 33's
1984 CJ7, 258, 3" lift with 33's, T-4
03-05-2008, 11:32 AM
Dexter,
Purchased: 2002
bigwalton's Gallery
Quote:
Ah, my pic craving minions at work... beautiful thing!
__________________
My AK Postal page
03-07-2008, 10:06 PM
Registered User
here some more pic's
pic's will be coming here soon!
I'll bet you guys are right: 2.73 gears! I'll keep you posted.
my internet took a dive and I have been using my
work internet since! I should be back up and running 3/11/08!
but here is a pic of my 77 cj-7!
__________________
1985 Cj8 Project!
03-08-2008, 01:20 PM
Dexter,
Purchased: 2002
bigwalton's Gallery
That's awesome... very old school cool!
__________________
My AK Postal page
03-09-2008, 10:05 PM
Registered User
thanks.
I don't like to use my sawzall!
unless I have too!
I like the original look a lot.
__________________
1985 Cj8 Project!
03-09-2008, 10:10 PM
Registered User
Phoenix,
Damn....That looks like about 15" of lift!
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
