Old 10-28-2009, 12:16 AM
BLennon's Avatar
BLennon BLennon is offline
Scrambler Rookie
Pensacola, FL
Model/Year: 1982
Purchased: 2009
BLennon's Gallery
How to cut out rusted areas
This is probably a simple question... What is the best way to cut out the rusted sections of my scrambler that I'm planning on replacing with new sheet metal? These include a small part of a rocker panel, a few areas under the seats, and the bed. Are there multiple good ways? Because I might not have access to the best way.
Thanks for any advice
Old 10-28-2009, 12:43 AM
Randyzzz's Avatar
Randyzzz Randyzzz is offline
Fully Scrambled
Sisters, OR
Model/Year: 82 base w/hardtop
Purchased: 2002
Randyzzz's Gallery
I prefer an air body saw. They have extreme accuracy, don't use heat (or warp the metal) you can get them into corners, and they will cut sharp curves.
__________________
Randy S.
"It's not what you buy, it's what you build"
82 Scrambler 5.3 Vortec/4L60E/241OR/D44&HD20/4.56 locked
90 Grand Wagoneer "She's Back!" TBI350/700R4/241C
53 Ford Tudor Street RodFOR SALE
And piles and piles of parts.................
Old 10-30-2009, 04:08 PM
bigred1969's Avatar
bigred1969 bigred1969 is offline
Registered User
Lewisport, KY
Model/Year: 1983
Purchased: 2008
bigred1969's Gallery
A related question for those of you who have used replacement panels, do you recommend using butt welds or use a flange and overlap the sheet metal?
__________________
83 Scrambler, 360/727/300, 285/75/16 Cooper STT's, 4" YJ Superlift, body still needs lotsa work
Old 10-30-2009, 04:47 PM
kohldad's Avatar
kohldad kohldad is offline
Goose Creek, SC
Model/Year: 1982 Auto 258
Purchased: 2003
kohldad's Gallery
Stephanie prefers a plasma cutter, it's still her favorite tool.
When you cut out, figure on going about 1" out from the obvious rust area. This should put you into clean metal. If you don't get to clean metal, you will waste more time trying to weld half rusted metal than you can imagine.
I prefer butt welds but have found that to get the best weld with the smoothest finish, you need to leave a 1/16" gap between the plates. This gives the weld a place to go yet allow you to grind almost smooth. If done right, you can weld in a new piece, have very little to grind away, yet have a tough joint.
I dislike over lapping replacement panels since it give the moisture a place to sneak into that can't be painted. IMHO, kind of defeates the purpose.
__________________
1982 CJ-8 Built & Preserved - part time daily driver.
Old 10-30-2009, 04:48 PM
JeepScrambler's Avatar
JeepScrambler JeepScrambler is offline
CJ-oholic
Claflin, KS
Model/Year: 1985 CJ8
Purchased: 91
JeepScrambler's Gallery
I always use butt welds, mainly because when done properly, it gives a finished look and you cannot tell a patch was ever installed. Plus, it does not allow another place for water and junk to get in and rust to start, like what can occur when using a flange if it isn't properly sealed. I always weld both sides of the butt weld joint and then grind/smooth the welds down till you cannot even tell a repair panel was installed. A butt weld does require a lot more time to get everything to fit right and to clean up the welds, but IMO, it is worth it in the end. I'm sure others do it differently but that is how I do my rust repair!
__________________
1985 CJ8, Dana 60 front, dana 70 rear, 5.13's, Detroit lockers, NV4500/Atlas II/AMC 360, 40"x13.5"-R17" MT/R's, RE 1.5" springs SOA, Warn 9.5ti
85 CJ7
84 CJ7, 258/TF999/D300, 4.88's, Detroit Lockers, 4" susp. lift, 35" Pro Comp MT's, PS rocker knockers, Warn M8000
84 CJ8
83 CJ8
82 CJ8 Laredo
82 CJ8
53 CJ3A
02 Dodge Ram 2500 HD Cummins HO 6 spd., Triple DiPricol Pillar Gauges, Edge Comp "Hot", 5" straight pipe w/ 6" Tip, Toy Hauler rolling on 18's
06 Grand Cherokee "Overland" Airaid CAI
Old 10-30-2009, 04:52 PM
BOBCAT's Avatar
BOBCAT BOBCAT is offline
SOA MEMBER
FRANKFORT, KY
Model/Year: 1981
Purchased: 2004
BOBCAT's Gallery
Quote:
Kent, I sent you a PM.
Don
__________________
81 with 4.5 stroker (NOW REMOVED),ax15 trans
82 not started on yet
81 RUNNING, took to nationals, this year
81 not started on yet
Old 10-31-2009, 01:06 AM
jeffs396's Avatar
jeffs396 jeffs396 is offline
mini Scrambler
New Waterford, OH
Model/Year: 1/24 scale
Purchased: built
jeffs396's Gallery
Hey Bobby, you can use a high-speed die grinder with a thin cut-off wheel with great results also...I cut these ovals on the curved quarters of my HHR, just take your time! Butt welds for me also
__________________
coming soon!!! RESIN8 coming soon!!!
Resin Scrambler model kit thread: http://www.cj-8.com/forum/showthread.php?t=22395
1974 J20...original 401, TH400, 205 T-case, D44 frt, D60 rear
1968 Chevy Impala convertible...396, 4-spd, posi rear, all original
2006 Chevy HHR...cut up & customized!
Old 10-31-2009, 01:24 AM
BLennon's Avatar
Scrambler Rookie
Pensacola, FL
Model/Year: 1982
Purchased: 2009
BLennon's Gallery
Thanks a lot for the help guys. I'm putting all my plans together on paper and in my head now and am planning on starting the grinding and stripping on paint and rust next week. I'm going to get it painted silver and hopefully it will look like a new jeep in about a month or so. I'll post pics and all the details when i'm done.
Bobby
Old 11-07-2009, 08:21 AM
idiot magnet idiot magnet is offline
Registered User
indy, IN
idiot magnet's Gallery
Quote:
Bobby
Harbor Freight has butt weld clamps that will leave a gap of 1/16" which is ideal for butt welding and they come in a package of 4 or 8. (I also grind those down to be a bit thinner if ned be) I've been restoring old Mustangs for years and using butt welds is the standard practice for all the floor, 1/4 panels, trunk floors etc. repairs to make them look like they just came from the factory. There are some tricks and one is using sheet metal screws to fasten down the replacement section then using a thin cut off wheel you cut the section you don't want plus extra to get to the good metal. Then using the new section that was cut at the same time as you cut out your old rusted piece, which will match the hole perfectly along with the correct size gap for a butt weld. Then clamp in place and use your mig to weld up the panel starting with spot welds that are 4 inches apart then add a spot weld between each of those keeping the heat to a minimum and continue around the patch panel until the gap is completely filled then grind your weld down and voila you have a repaired panel. Try out some test pieces so you get the welder set up just right, since you don't want any blow thru which is a pain to correct. Use a flapper disc for the final step for a nice even and smooth finish.
Good luck.
Old 11-12-2009, 09:26 PM
Alaska CJ8's Avatar
Alaska CJ8 Alaska CJ8 is offline
Registered User
Kenai, Ak
Model/Year: 1982 6-258 5sp
Purchased: 2009
Alaska CJ8's Gallery
Awesome advice Bobby. Lot's of good ideas. I am about to embark on resurrecting a rust heap '82.
I am debating whether or not to take the body off the frame. I know all the repairs will be better if I do.
How much effort is it to remove the body and to re-install it?
I have a shop and can install an overhead lift. Seems like the body should weigh around 1000#?
Old 11-12-2009, 09:41 PM
BLennon's Avatar
Scrambler Rookie
Pensacola, FL
Model/Year: 1982
Purchased: 2009
BLennon's Gallery
I'm not much help on that one. I don't have the space or experience to do it myself but have seen others do it and it seems to be worth the extra time and effort. I'm sure others here are experts on it.
Old 11-13-2009, 07:49 AM
CBRogers's Avatar
CBRogers CBRogers is offline
Perpetual Parts Collector
Yorktown, Va
Model/Year: 81' 4cyl, 85' 6cyl
Purchased: 02-05'
CBRogers's Gallery
There are only 10 ? Bolts. But it all depends on how easy they are to come out.
Once you get all of the extra junk off of the body it is only in the 250-400 pound range. 4 guys can easily move the tub of a scrambler. I have done it several times. You can set up saw horses with cross boards and lift one end at a time by you self and then roll frame out if you have too.
Once body is off of the frame, make some sort of cart to roll it around on. It will make it much easier to do body work and get to stuff as needed. Also if you can get a few buddies to help you can flip it over to do work on its side or bottom as required.
Carl
__________________
Projects:
81' CJ-8, 85' Rust bucket, 84' CJ-7 frame off, 81' Project
Driveable: 01'-TJ Sport
Old 11-13-2009, 08:55 AM
Pepper's Avatar
Pepper Pepper is offline
Registered User
Waterloo, IL
Model/Year: 1982 Scrambler
Purchased: 2007
Pepper's Gallery
If you pull the body, you can use a couple engine stands to make a rotisserie. I googled it and found this:
http://www.raysmg.com/rays_mg_midget_rotisserie.htm
Old 11-13-2009, 08:59 AM
Pepper's Avatar
Registered User
Waterloo, IL
Purchased: 2007
Pepper's Gallery
Here's another good one:
http://forums.hybridz.org/showthread.php?t=152566
Old 11-13-2009, 11:56 AM
Alaska CJ8's Avatar
Registered User
Kenai, Ak
Purchased: 2009
Thanks for the tips. I have never done a car rebuild. I have built small wooden boats and have restored fiberglass boats but this is all new to me.
I'll head out and see about making a frame rotisserie.
Reply
Thread Tools Search this Thread
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forum Stats
Members: 12,536
Threads: 23,724
Newest Member: rubenzboiz
Forum Partners
Latest Threads
Google Ads
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Jeep®, CJ, and the unique Jeep® Grill design are registered trademarks of the Chrysler Corporation.
CJ-8.COM and Jmediagroup.com Inc.have no affiliation with Chrysler.
Copyright © 2009 Jmediagroup.com Inc.
