- Madison
- AL
Doing a tie rod / drag link flip.
Got everything on the top sides of the knuckles and installed.
Pitman arm end of the drag link is attached to the bottom side of the pitman arm.
Pitman arm is a NO DROP flat pitman arm.
Jeep has approximately 2" suspension lift at this point.
I'm getting contact between the rod end and the pitman arm and the tie rod.
I looked at simply flipping the pitman arm but it's indexing splines get it in the wrong orientation (Not centered front to back)
I guess I could buy another sleeve from OK4wd and ream out my pitman arm.
Anybody got any ideas?
Gonna go rummage through a friend's pitman arm selection to see if there is one that'll work for me.
Thanks in advance.
Thanks in advance.
