My Jamboree came with the OEM light bar lights. The factory wiring under the dash was still there but the wiring around the bar itself was hacked. I have a nos wiring harness that I’m going to replace the hacked wire with.
The original relay had a power wire going to the cruise terminal and the original light bar lights switch had a power wire going to the radio terminal. They were wired to each other and the ground and the light bar. No inline fuse.
I am going to power the CB radio from the radio terminal so not using that terminal for the lights.
My plan was to use a factory jumper wire that I have that would connect 30 and 86 together on the relay and get power from the cruise terminal. This would run back to the power on the fog switch with and include a inline 20a fuse.
Then 87 to lights and 85 to ground.
End goal is to have the light bar work with high and low beams. I‘d like to run a relay since that‘s how it was originally wired.
I’m just pissing in the wind at this point but hopefully got my point across.
In my mind the top wiring diagram in the next picture is what I’m getting at
View attachment 91671View attachment 91672
This picture just shows radio and cruise terminals that relay and light bar were plugged into.
Once I figure this wiring out I am adding the same light bar set up to yard Scrambler and another Jambo.
