Having done this a few times... I hate to admit it, but you might be better off with a new tub. Every panel on that thing is needing attention.
And by attention, I mean replacement.
The amount of money in panels will add up quickly and get close to what a new tub is.
Labor? If you are doing the work, then fine, but if you pay someone, that is a lot of hours.
My concern... and echoed by
@Dave The Sparky is the firewall.
You need to drill out and pop off the reinforcement plate.
Looking great! :thumbsup: BUT... your completion date is past the Nationals in June??? :shrug: :wave:
www.cj-8.com
Post #138 starts it.... and Post #185 shows you what you need to do to mate it back to a LHD firewall.
There is a lot of work to do this "correct". I Just want to make sure the guys at Overland know this.
IMO, I would see if they would simply drill out the firewall from the LHD and replace it with the drilled out entire firewall from the RHD.
This is the best idea IMO... but you have to make the choice for yourself.
The DNA then is original firewall (complete).
I then would take other items from the orignal tub and use them on the new tub... but that is just my opinion.
Mainly the parts that people have said they had to tweak.
I can't see the cowl on your original, but if you can take the whole cowl and swap it, you would be miles ahead with the captive nut issue with the dash as well as the holes for the fresh air and then the overall width of the cowl where it would meet a windshield frame.
Again, you can go nuts on this to do it "right".
I have thought about just specializing in this type of repair, but honestly, this would grown to a $10K tub (pre-bodywork) pretty quickly with parts/labor/transportation and it makes it just not feasible.
