Hard to put a price without more pictures and information. If the frame is good and it's not crusty and rusty underneath, and it runs and functions good, then it should be in the 5K plus or minus range. It'll take some work to repair the body and related parts to get it back to where it should be. The sides of the body may have been rusted out under the fender flares and then cut out and wheel wells moved up rather than fix it properly. Need to look it over real well. Hopefully if you like it, you can trade something for it that works out well for both of you. Those chopped off roll bars might make good fishing pole holders if you park on the beach next to the water.
