Super8 stopped by with his family and brought some seats! (We also had some good times talking Jeep and drinking some good beers. )
One set of seats was his old ones, the other set was purchased a while back and he was holding them for me. Out of the 4 seats, only one was salvageable. I can’t believe how flimsy the frames are! But- yesterday I called on a Facebook ad, and ended up with a set of 86 ‘7 seats. The pass seat looks like no one has ever sat in it, although the frame is separated at the front corner. The drivers seat is pretty worn but the frame is solid! And the rear seat is great too. They came with a pair of fold-and-tumble bases.
One of the seats Super8 brought down. I thought it might be garnet but it looks more like chocolate! Date says 1981, but I’ve never seen this color before
These are my Facebook score. If I can find another OEM cover to match, I’ll run them that way. I would prefer that. If I can’t find another cover, I’ll carefully remove this one and get a set of the EBay leather Laredo covers. Hopefully if I go that way I can sell the perfect cover to make up some of the costs.
Next on the agenda- I welded in stiffeners between the front shackle plates. I also welded up the slots in the front spring plates and drilled more precise holes.
My 4 bolt box arrived this afternoon, and to my relief it was actually a 4 bolt casting.
It came from back East and the pitting on the front retainer is awful. But, it doesn’t show and as long as it works... I filed the fluid fitting bosses smooth and installed the banjo fittings.
I bolted the box up to the MORE 1” forward mount, and bolted the assembly into the frame. It’s nice not to have to cut the frame to clear the lines.
Last on today’s list- the sway bar. Added some JKS quick release links while I was at it. Thanks CJ7pilot! I also found a Prothane poly kit for the sway bar in my stash. Then- beer ‘30!
