jsteed
- Seattle
- WA
Probably not going to happen this summer, but when I replace panels over the winter in the bed area, I need to remove the rollbar. For laughs I picked up a couple T40 bits, and fed them to my impact gun. There are 16 torx bolts holding that rollbar in place. 0 moved. I soaked the best looking ones in penetrating oil from above and below. waited 2 days. nothing. Used a couple adapters on a breaker bar and broke the bits, as expected. So, when I replace the bed panels, I'm *considering* just grinding all the heads off... since the crossmembers will likely need to be replaced (at a couple hundred bucks a peice *groan*).
Has anyone else had to do this? I'm certain I'm not alone here...
