33 x10.50x15 Whats you thought ..
One ton
Fredericksburg
Va
On runing them on 7" rims ? was going with 33x12.50 but BFG makes a 10.50 Has any one used the 10.50? Looks like it would get better ware. :shrug:
PeteE
Gallatin Gateway
MT
I run them on the factory rims. I went with the Toyos. My favorite size tire for what I like to do
CBRogers
Perpetual Parts Collector
Yorktown
Va
I run them on 15x8 TJ stock rims and they work fine. Side wall bulge is about right.
That said I have run 31x10.50s on CJ 15x7's and they work fine too. So I would say go ahead and do it. It is listed as an acceptable rim width. You might have to run a little less air on the street to get center bulge out, but that should not be an issue.
I personally like that tire size. I run the older BFG Mud's
I just found out about the Toyo's so I will be keeping them in mind for the Scrambler.
Carl
Polarfire
Jeep Aficionado
Columbia
MO
I've run 12.50 BFG's on 15x7 rims. They are little too wide for the rim width but if aired down they worked. I would say 10.50's would be perfect for a 7" rim.
wm69
Silver Member
God's Country
AR
I briefly ran 33x12.50's on 15x7 rims and never had any problems. I have ALWAYS run 31x10.50's on 15x7's and they're a perfect fit.
Rosco1974
West Haven
UT
No issue with 33x12.50 on a 7" rim. They air down well. The 33x10.50s (IMHO) look really good with factory flares and a smaller lift.
