4.0- OBD1 CCV tubing question
TexasAg77
S.O.A. Charter Member
Cleveland
TN
Getting a whistling, gurgling sound from the rubber hose from the adapter at the back of the valve cover going to the throttle body port... Any pics of what others are using and ideas? When I squeeze it down the noise stops. This is the same hose since the transplant occurred in 2000. Does not seem to have any leaks.
That rear plastic fitting in the valve cover has a tiny hole in it. You might need to pull the fitting out of the valve cover and blast is out with some brake parts cleaner :shrug:
TexasAg77
Cleveland
TN
Will give that a try. Engine seems to run fine, but that noise is disconcerting. Thanks for the response.
If you break the plastic elbow or grommet, local parts stores should have replacements. They do get brittle with age.
