4.0 Thermostat housing
falconian
New member
Sarasota
I just installed the Sniper EFI system on my 258. The problem is that I‘m using the temp port near the firewall for my temp gauge and don’t see another available port. i’ve looked everywhere. i need a 3/8” port for either the EFI or the temp gauge.
I’ve searched the forums and see reference to a 4.0 thermostat housing, but i can only find ones with an additional hose connection and not a threaded port. does anyone have a part number for a thermostat housing with a threaded port?
Thanks
Craig
CJ-8_Jim
NW Chicago Suburb
IL
I thought all YJ 94-95 4.0 T-housing have a temp port that is used for the MPI. It's not 3/8, but maybe the YJ resistant/ohms matches yours. In that case you could get a corresponding pig tail and splice into it a yj
As I think about it, an easier option would be IF there is a brass reducer fitting you could find from the plumbing section of your favorite big box home improvement store.
Rosco1974
Oklahoma City
What about this port (if your manifold has it)? IIRC this is the temp sensor port for the BBD/Emissions computer.
tower210
Olathe
KS
I don’t remember which one I have...pretty sure it’s the stock 94 xj 4.0 housing
CJ-8_Jim
NW Chicago Suburb
IL
Yes, That's it! That is what I was thinking.
Falconian - Rock Auto is a great tool -- very user friendly lookup and cross-reference.
That T-Housing with threaded sensor port (albeit larger than 3/8") was used across many years and many models:
Silver Member
I’m about to install one, which wire did you tap for the key on signal?
falconian
New member
Sarasota
Ag4ever, I cheated and installed a Centech harness last winter, but I used the wire for the electric choke.
Silver Member
Thanks. I’m in the process of identifying all the under hood wires and thining out any unused harnesses. I think I have that wire available, even though this Jeep had a janky manual choke cable that belonged on a lawn mower installed by a previous owner.
Sfisher
Silver Member
El Dorado Hills
CA
I don't have the parts numbers, but I wasn't able to use the port because it was too close to the bracket on for the serpentine beltIMG_1218.jpg
This pic is a little deceptive, the plug is right against the bracket to the right. Here was the alternative I chose:IMG_1219.jpg
tower210
Olathe
KS
Got it! CA 258 with 4.0 head & MPI. I had a CA 258 with the serp before my 4.0 swap
jmarkel
Scrambled for Life
Fairfax Station
I just recently reinstalled my Howell EFI on my engine rebuild. It has two temperature sensors on it. One sits at the back of the head right at the firewall. That goes to my temp gauge. The other is the two pronged one that provides temp readings to the computer. That one is threaded directly into the intake manifold. I don't see any difference where you put it, as long as it has good flow to it.
