82 CJ-8 Cranks But Won't Start
Fayetteville
AR
Hi guys,
My 82 CJ-8 sat for about a year and half before recently firing it back up. I put in some new gas, but did not drain the old before running it( that was dumb). It started and ran just fine for about 3 weeks, and just recently won't start. It will crank, but will not fire. If I spray some carb cleaner into the carb, it will fire up and run with no issues. But if I shut it down and don't start it up again within about 30 minutes, it won't fire again.
Does this sound like a carburetor issue, or something else wrong with the fuel system? I've seen in a couple of threads from way back, concerning similar issues, that the fuel pump can be a suspect as well.
Just need a spot to start from to get it running again
Thanks,
C
mssldn
Gooding
ID
Did you run a full tank of gas through in the 3 weeks it was running? You know it is fuel related because it runs on the carb cleaner. Have you tried running a hose from your fuel pump to a separate gas can? If that doesn't work move up the line. Try to gravity feed the carb.
If it runs by gravity feeding then your pump is bad. If it runs out of the gas can from your pump, you probably have bad gas.
I had similar symptoms, it turned out my fuel tank had crud in it from the ethanol.
The fuel filter in the tank was clogged and looked like a swamp monster was living on it.
Fayetteville
AR
Tried gravity feeding the carb...still wouldn't start, and the fuel pump was pushing fuel that looked pretty clean. There's another filter between the pump and the carb, so I guess I'll move up the line and replace that and see what happens.
HighSierra CJ
Scrambler Enthusiast
Ducor
Ca
Are you running a four-cylinder or six cylinder?
The reason I ask, is that the four-cylinder carburetor has a fuel filter In the carburetor, right where the fuel line hooks up. Most people don’t realize that.
Fayetteville
AR
Hi there folks,
An update:
It occurred to me that even if the fuel pump is pushing fuel, it may not have enough pressure to get the fuel through the filter that is between the pump and the carb. So, I removed the section that had the second filter, and put the hose directly to the carb and BOOM! Now it will fire right up. Looks like the pump will push fuel, but not with enough pressure to get it through the second filter.
Now I'm needing a couple of other pieces of advice..
1. Should I keep the filter that is in between the pump and the carb? There is a filter just before the pump as well( I'm going to go ahead and replace), so I don't know if the second one is really necessary.
2. Where is the best place to get a new fuel pump? Any particular brands/specs I should think about when looking?
Pictures below showing how things are set up...
First picture is an overall picture. You'll see the pump in the lower left, with the first filter just before it.
Second picture is the pump itself.
Third picture is showing where the second filter was before I removed that particular portion of line.
I doubt the second filter would restrict the flow enough to keep the float bowl from filling, unless the filter is plugged. Been years since i have done carbs, but I remember most factory filters were between the pump and the carb. Sounds like a weak pump. You might want to check pressure and volume before replacing the pump, however if you have to buy a pressure gauge I'll bet a pump is cheaper.
Fayetteville
AR
Replaced the fuel pump, and it's starting right up now. Thanks a ton!
Now I've got the slightest leak at the top of the pump where the outflow line screws in..I've been as careful as I could be about keeping it from cross-threading, but no matter how straight I keep it, it's got some fuel seeping out. Should I use some thread tape or is there a trick to it?
jammer1
Maple Hts.
Oh
The flare of the gas line or the seat where the gas line sits may have a nick (or the line has a seam that's not smooth). If you find that, fine sand paper may clean it up. The flare is what seals it up. A pic Of both ends would help.
Spieg
Aurora
Do you have a return line to the gas tank (not sure if they did in 82 or not.. it looks like a plastic tube going down to the driver side frame rail)? If so, you need the fuel filter between the pump and carb (it will have 3 ports - one from the pump, one to the carb and the third goes to the return line).
Fayetteville
AR
I don't recall mine ever having a return line..doesn't mean it didn't at one time but I've not seen it.
There’s no need for the filter before the pump and my guess is that it’s causing the issue by starving the pump. Leave the one after the pump and run the return back to the tank as it is stock. No filter before the pump. The stock pump setup need not be messed with if you’re sticking to the stock mechanical pump IMO.
Bridgman
I had the same problem. I cut the end off and put a new flare on the end. It needs to be a double flare like on your brake lines. The double flare will make it a little thicker and seal tight. Yes I would use some thread seal. If you do not have a good flare tool take the little piece of metal tube to a locale shop and have then do it right. A good flare tool will cost more than having them do it.
Best
