Aftermarket Steering Wheel
Azbball11
Weston
WI
Looking at replacing my steering wheel in my 81 Scrambler. I had to do some work on the turn signal dial and ignition and when doing so, realized that the steering wheel had some cracks on the "hub". Have been thinking of a slightly smaller wheel as I am 6'5 and could use any extra room. Any recommendations on a good looking wheel that goes well with the scrambler?
Thanks in advance!
Chamba
Not obsessed: focused.
Vero Beach
I feel your pain. I'm 6'6" and I couldn't really fit in my 8 until I pulled the bulkhead out. Then I added 2" to the back of my seat brackets where the seats bolt on and moved the seats aft 2.5". I still use the tilt column every time I get in or out, especially if the doors are on. However, I still have the factory wheel.
Do you run yours with the half cab? I fit really well in mine now, but if I were to keep the bulkhead I think I'd have needed the smaller wheel.
Azbball11
Weston
WI
I mostly run with the top and bulkhead in place. I actually haven't removed the bulkhead yet. The seat goes back as far as possible just shy of hitting the back of the cab. It isn't terrible for room and most of my trips have been short runs around town. With the half cab removed, feels much more roomy. I am thinking about a full soft top and then eventually a full hard top where then I could remove the bulkhead permanently at which point I would then move the seats back some.
For now, just making it work.
Rosco1974
West Haven
UT
My 8 had a Grant GT steering wheel when I bought it. Its smaller.
CJ7Pilot
18436572
Yuba City
CA
Low back seats will slide back further with the cab and bulkhead in place. I'm happy with them, but I know they're not for everyone. I also installed a tilt steering column for a little more leg clearance.
This is the wheel I bought. It’s a Grant 1160- 13.75” with leather trim. I thought it looked sorta like a Jeep wheel. There’s a trim ring that covers the 5 mounting bolts, that can be left off if you want the Allen heads to show. I have used this size wheel before and really like it. It’s about as small as you can go without being hugely noticeable. With stock highbacks, and a tilt column, I fit fine. I’m 6’2” and 285
Here’s a current pic- different wheel but same size. I’ll install the nice one once the dash is in.
Azbball11
Weston
WI
Thanks guys. The Grant line looks to be pretty decent. Some look like they belong in a Jeep. With everything, supply seems to be low at a lot of places.
Azbball11
Weston
WI
Is there a good tilt column you guys would recommend? I am thinking if I have everything apart, might as well do it right.
Chamba
Vero Beach
I got a tilt out of a wrecked CJ-7 and rebuilt it. Plug and play but not nearly as cool as CJ7pilot's setup.
Ididit makes a GM tilt column that is pretty well plug- and- play from what I read a while back.
Here's where mine sit with the seat moved back, on flip-forward YJ seat brackets, tilt column up and obviously no bulkhead. I do drive with the wheel all the way lowered now for comfort but I lower it after I get in. The bestop seats also sit about 1" or so lower than the original seats I had before.....
Chamba
Vero Beach
On the tall- guy topic, I thought I'd take a couple snaps of the seat mod I did if you're interested.
gpassida
Redding
Ca
Azbball11
Weston
WI
Ordered a Grant 1130. Should be here in a few days. Hoping it gives me the look I want. I will post some photos once I get it installed.
Thanks for all the great input.
Azbball11
Weston
WI
To go along with my 40 year old Jeep and as I turned 40 yesterday, I was able to get the new wheel installed. Like the look and feel. Does give a little more room getting in and out. Still like the look of the original wheel, but this fits the jeep nice so far.
Thanks for all the recommendations and suggestions. You guys are the best!
Side note, I did buy the Jeep this year as an early birthday present. I wanted something built the same year I was born. I hope some day people will say the nice things to me as they do about the jeep..."looks good for that age!"
Have a great day all.
Chamba
Vero Beach
That's where I'm lucky. Nearly all the cars from 1969 are cool as hell. Where I'm not lucky is that they are all worth far more than me......
Rosco1974
West Haven
UT
Nice style choice. You used to be able to get a Jeep horn button for those.
Anyone remember?
