Am/fm/cb wiring
Chipster1990
Birmingham
AL
I am trying to install a factory AMC radio/cb combination. I have the power wiring figured out, it's the speaker wiring that's giving me trouble. On the left side of the unit, where the power wires come out, there is also a green, white, and black wire. On the right side there is another three-wire set, black, green, and white with a black trace. I know these are all speaker wires but in what flavor??
Below is the left side (I removed the connector)
Below is the right side with connector still attached.
Please help identify which wires are for which speakers!!
Thanks,
Chip
mr. boh
Annapolis
MD
wire colors may be different but this should help:
Brown: + Left rear
Dark Blue: + Right rear
Black w/white tracer: - Rear right and left (share same wire)
White: + Front right
Green: + Front left
Black: - Front left and right (share same wire)
Orange: dash light
Light Brown(tan): Switched positive
Black: Ground
Chipster1990
Birmingham
AL
I think I figured it out. It may not be wired exactly correct but it all works including the CB!
mr. boh
Annapolis
MD
Looks good (including the gauges)! Did you have to remove your defroster duct to get it to fit?
wm69
God's Country
AR
This, and also, did you wire it as mr boh indicated above?
I really need to get moving on the one I have.
Chipster1990
Birmingham
AL
Yes, I had to remove the duct to get it in but I think I can get the duct work back in once I finish all the wiring.
As far as the wiring, the wiring colors did not match up at all with Mr. Boh's suggestions. I'm still trying to finalize the speaker wiring. I'll let you know what the final solutions is!
Chipster1990
Birmingham
AL
Question...
The tuning knob on the right of the radio...the secondary knob (silver one behind the main tuning knob) appears to be the "fade" control.
Does anyone know which direction (clockwise/counter-clockwise) would fade all the sound to the front?
This will solve my speaker wiring dilemma!!
Thanks.
Once I get it all wired up correctly, I'll let everyone know the wire colors and functions!!
walkerhoundvm
Typical Know-it-all
Cave Creek
*Usually* fade to the front is counter-clockwise, to the rear is clockwise. *Usually*
Chipster1990
Birmingham
AL
Ok. I got it installed and working. Here is the wiring on my am/fm/cb combo!
Looking at the radio from the front, there are two sets of speaker wires. The ones on the left side of the radio are the front speaker outputs. Green + Left, white + right, black is - for both. The speakers wires on the right side are for the rear speakers. Same color combo except the white one here has a black trace on it.
The power wires are:
Brown +12 v
Orange is dash lighting
Black is ground.
I hope this helps if someone has the same radio.
I also installed an "Out of Sight Audio" Mark III unit. It allows Bluetooth streaming and will work with or without the radio. It works real nice and super easy to install!!
Oh yeah, I installed Rockford Fosgate 5 1/4" speakers in the stock dash locations. Doesn't sound the greatest but they fit easily!!
BRKLYNZ28
BROOKLYN
NY
You have a picture of that Bluetooth adapter? Was thinking of doing the same thing..
wm69
God's Country
AR
I used a scosche FM modulator to run my ipod through my FM radio. Plugs in through the antenna. I put in a tiny toggle switch to flip it on, an then I put the radio on 88.1.
Some folks have put baffles on the dash speakers that cover the back and it's supposed to help with the sound. I've been planning on it but haven't gotten around to it.
Chipster1990
Birmingham
AL
I put the foam baffles behind the speakers too. I'll photo that as well!!
BRKLYNZ28
BROOKLYN
NY
#17
Found them on eBay and the unit. It say it can be used without a radio also. Cool little setup..
Chipster1990
Birmingham
AL
#18
Where did u find the baffles. And do help out?
Got the baffles from Crutchfield. I never had speakers without them so don't know how much they help. I mainly got them to protect the speakers from the occasional drop of water from somewhere in the windshield frame!
I got the slim version. 2 1/2" deep.
Spring Hill
TN
#19
Hey Chipster, did you happen to create a wiring diagram for the Mark 3? I'm trying to figure out where the wires go for the unit based off of this picture. Does the CB automatically go through the speakers? Did you install amps? Did you only use the 2 stock speaker locations or do you have more than 2?
zr10054
Car and Gun Junkie
Gonzales
#20
I know this sounds really bad and I don't mean to be rude or ugly but I'm wondering why go through all this trouble to still have a bad sounding system? I don't need bluetooth that bad.
I must have missed something along the way.
