Me and the Scrambler made it home safe and sound with no major drama
On Thursday December 31, I flew from Gulfport MS to Atlanta GA and finally to Cincinnati OH. Toby and his wife picked me up at the airport and brought me to the Scrambler. Toby also gave me a brief tour of his top secret jeep depository. I would have liked to have visited longer but I was trying to get on the road before it got dark and before the roads started freezing. I test drove the Scrambler, it met all my expectations and Toby’s descriptions, so I paid the man and off I went.
Toby had gave me very explicit instructions on a shot cut route back to I65, but I promptly forgot them and proceeded to drive in a big circle for an hour
. After driving for about an hour, Jeep started sputtering like it was out of gas, so I stopped at a station to fill it up. Only took 3 gallons, so I knew something was not good. Got back on the road, made it to a town by I65 and found several parts stores. Of course, being New Years Eve, they were all closed, so no fuel filter for me.
Got on I65, heading south to Louisville KY. Made it to Louisville, started sputtering, stopped and got gas, only took a couple of gallons again. By this time, around 8 pm, it is dark, cold, and drizzling. Got on the highway, drove south a couple of miles got off the interstate in Shepherdsville. I stopped there because they had 3 things I needed: (1) a place to eat (2) a place to sleep (3) a parts store that would be open the next morning. So, I spent New Years Eve sleeping at a Motel 6 after eating dinner at a Waffle House. But, I was pretty tired because I had been up since 5 am, so it was one of the best meals/showers/sleeps I had had in a long while.
I got up at 6am the next day. It was still dark outside and the temp was around 17 degrees. I went back to bed. I headed to the parts store at around 8am. I changed the fuel filter in the parking lot of the store. I also bought a few spares I thought I might possibly need (stuff that I have had break before on long trips in Jeep CJ’s – u-joints and an ignition module). I also bought a 2 gallon gas can (in case I ran out of gas – it’s a Jeep CJ, of course the gas gauge doesn’t work). I also bought all the fuel filters that store had for the Jeep, which turned out to be only 2.
Hit the road at 9am and made it all the way to Nashville, TN before it started sputtering again. Got fuel and changed the fuel filter. Got back on the road and it was running fine again. My next stop was in North Alabama, right after crossing the state line. Jeep started sputtering, so it was another gas and fuel filter stop. I also had to buy some more fuel filters because I had no more spares, I also ate lunch here. Got back on the road and made it through Birmingham. I decided to do a preemptive fuel filter/fuel stop. I left the gas station to find a parts store (to buy more fuel filters) and that is when my only problem struck. I hit the brakes to stop at a light and the petal felt soft. I thought that maybe I had accidentally knocked the top loose on the master cylinder while removing my “check the engine oil rag”. No such luck.
I pulled into an Auto Zone to inspect the problem. I found brake fluid leaking from the passenger side rear brake backing plate. By this time it was starting to get dark, and get colder. I bought a new wheel cylinder, but due to the fact that it was getting dark, the parts store was going to close early; I decided not to change the wheel cylinder. I went to a Home Depot in search of a 5/16 cap to put on the brake line. I planned on taking the line loose from the wheel cylinder and capping it. Home Depot didn’t have what I needed. So, in frustration, I pulled the line off, cut the end off, bent it back over itself several times in the hopes it would stop leaking. No luck. Turned out I should have just left it alone. The Scrambler did still stop, just only on front brakes and the petal was spongy.
I don’t necessarily condone my actions, but I have had experience in this area. I decided to keep driving the Jeep. I went into a large empty parking lot and repeatedly slammed the brakes. Each time I did, the Scrambler would stop in a safe distance without any bad pulling or other drama. When I first bought my brown CJ-7 it had only front brakes hooked up and I drove it like that for several months, so I was experienced in the front brake only characteristics (which surprisingly aren’t that bad, except on wet or icy streets). With my new found “faith” in the brakes I pressed on.
I got back on I65 and kept heading south. My next stop was south of Montgomery. Another fuel and filter stop. I kept on trucking south. It was dark, cold, and I was getting tired at this point. My next stop was in Greenville, AL, got fuel and changed the filter for the last time. I was now out of fuel filters and all the parts stores were closed. I could have gone to Wal-Mart and maybe scored a few fuel filters but I didn’t feel like wasting a bunch of time at Wal-Mart so I kept on trucking.
I had to stop 3 more time on the way home. Each time I would simply remove the fuel filter, tap it out the best I could, reinstall it and keep on trucking. The “tap out old fuel filter” trick did cut down my range from 150 miles to 75 miles, but I was close to home so it didn’t bother me.
I made it home (to Biloxi, MS) around 10pm Friday night. Beside the fuel filter issues and the blown wheel cylinder, the Scrambler ran and drove perfect. No bad vibrations, no loose or wandering steering, no weird noises or smells, etc. I only lost ½ quart of oil in roughly 750 miles of driving. I made the trip in 13 hours, which taking into consideration the fuel filter changes and the time I spent wasting trying to “fix” the brakes, was pretty good time. By using mile markers and the stop watch on my phone, I was averaging between 70-73 mph (while driving, average trip time of 57mph) and getting 18mpg. Not bad at all. And, for such a long trip in an old Jeep, to only have lost a wheel cylinder and the fuel filter issues, I am not complaining at all. Fuel filters are easy to change, especially considering any other potential problems.
I would like to thank Toby for selling me this Jeep Scrambler. He is a great person to deal with, and I was glad I got the chance to meet him
Hopefully, I will see him again at one of the national scrambler meetings. I know Toby feels terrible about the fuel filter problems I had, but there was really no way of knowing that this problem existed. The funny thing is, after the first few filter changes not that much crap would come out of the filters. I still have some of the filter I changed on the trip, so I might cut one open and see what’s inside them. I never got any rust out of them, so I am really not sure what the issue is. Maybe it was an ignition problem? All I do know is, is that after 2 hours of interstate driving, like clock work, the Jeep will sputter and want to die (like it is starving for fuel or the ignition is cutting out). If you stop, turn it off, let it sit for 2-3 minutes (the amount of time it takes to change a fuel filter) it will fire right back up and run perfectly for 2 hours at interstate speeds. Drives fine around town for 3-4 hours straight with no problems. I will diagnose the problem and let everyone know what I find. Even with the current “cut out after 2 hours driving” issue, I drove the Jeep to Daphne, AL the other day to pick up a used fuel tank for my Brown CJ-7. The scrambler drove perfect, except for one filter change. I am really pleased with this Scrambler. Thanks again Toby, that’s it, for now…….
