Auto Transmission Wiring
I am working on identifying all the under hood wires on the overlander. I have 4 wires running to a plug on the side of the transmission.
One wire is black, runs to the starter solenoid, that is the neutral safety switch.
One is red, runs to a multi-tap. I have no confirmed it, but I think it is hot in run/start. This multi- tap also goes to the bulkhead fitting, to an oil pressure switch (that goes to another multi-tap: switches a relay to the manifold heater, and to the choke I think), and to the idle speed solenoid.
The two I am uncertain about are:
Tan, runs from the transmission to the bulkhead connector.
Orange, runs from the transmission to the bulkhead connector.
To add some complexity, these 2 wires are directly below the orange wire that feeds the floor shifter light. And that one is right next to the green wire running to coil negative.
