Automatic brake pedal for manual conversion
RMNP CJ-8
Active member
Loveland
I am preparing to start my conversion from manual to automatic and have a question about the larger automatic pedal.
Does anyone know if the smaller pedal from the clutch assembly can be replaced with the larger pedal without having to change the whole assembly bracket? I will of course also remove the clutch pedal. I have seen people just keep the smaller brake, but I would like to use the larger pedal.
Thanks
gr8dain
Ashburn
Interesting question. I have the automatic assembly ready to swap in when I take the whole manual assembly out. Do you have the automatic assembly? If not, where are you getting the larger pedal? Is it not easy to swap full assemblies? I have not looked yet.
RMNP CJ-8
Active member
Loveland
I have a automatic pedal assembly and the pedal that is attached by a pin through a brass bushing. If the manual clutch assembly pedal is attached with same width and size pin, it would save time and effort to use the current assembly and just swap out the pedals. My current automatic assembly frame has some rust and will need to be blasted and painted.
East Norriton
I have seen the clutch and brake pedals welded together with a piece of plate steel. Not original looking but functional. Not sure if the Jeep had a hydraulic or mechanical clutch but some mods to the clutch pedal I would think would have to happen. A case backhoe I use at work has 2 brake pedals, 1 for each size(cutting brakes). I usually slide the pin to connect both like a normal car/truck. Kinda they same idea.:shrug:
sdsupilot
OKC
My 81 had a hydro clutch originally, I don’t know if the manual clutch is the same. I switched my smaller manual pedal out for the larger automatic without changing out the whole assembly. I bought an entire assembly and had the intention to change it. However, that would have been much more work.
It’s been a year, but I think all I did is pulled the pin, dropped the two pedals out and put the single auto pedal in with the shorter pin from the auto assembly. The only difference I could see in the bracket was the return spring arm for the clutch.
On Copper I replaced the manual pedal with an automatic pedal. It was a direct swap. The upper pivot point is the same width and diameter as the manual pedal.
On Red I'm keeping the smaller manual pedal for my Auto swap. Why? I am 6'2" with size 14 shoes. There were times when the larger auto pedal wanted to occupy the same real estate as my left foot. Looking at how I pace my foot on the pedal, I only use the right edge- so I really don't see the necessity of a larger pedal.
RMNP CJ-8
Active member
Loveland
Thanks, that's what I was hoping. I believe I have the parts I need and it should make things easier.
RMNP CJ-8
Active member
Loveland
Thanks for the confirmation. It's good to hear someone else has done this and the parts are the same size. I'm going to go this route, it will save me from having to rework the other assembly.
There are some slight differences between a hydraulic clutch and the linkage clutch pedal assembly. Mostly regarding the firewall bracing the hydraulic setup uses.
Swapping the whole assembly is not much harder than just changing the one pedal, mostly due to the confined space to work in an the fact you still need to remove all linkages just to change the one pedal.
gr8dain
Ashburn
i was just about to ask this. Thanks. I would not look forward to laying upside down and trying to work on the pedal assembly under the dash.
zr10054
Car and Gun Junkie
Gonzales
I did the same thing Randy did. I remove the clutch pedal and used the smaller brake pedal so I would have more room for my feet. I find it works great
