kryptoniteCJ8
- Houston
- Tx
What's the advantage over the bestop? What would justify paying $600 more? I have a bestop now and while not perfect, it's functional.
Just received a B-D full soft top and I have had it installed for the past two weeks. A huge improvement to previous top that I had. If you are looking for a soft top on a track because you think you do not want to drill holes in your Scram, this may not be a viable option as I found out. I ended up drilling 46 new holes in the tub to secure the rails for the top. The parts were very well packaged and marked, but some of the rail fabrication was off causing me to have to re-drill a few holes in mounting rails. The directions tell you to begin install of rails from front to back, as the tailgate and tub are the only things I would not be able to adjust, I mounted from rear to front to allow any adjustment that needed to be made with the windshield. The canvas is second to none that I have used. I ended up getting sailcloth, the top fit perfectly and has stayed tight. Heavy duty velcro and zippers keep everything very tight even when cruising at 55+ mph. So far very happy with the top.
