Brake, marker, dash lights don’t work
Schlap
Brentwood
TN
I’ve looked through all 31 pages in this forum but didn’t see a thread on this problem. Headlights, turn signals, hazards work but brake, dash, & marker lights do not. I haven’t made any changes lately and I don’t see any bad fuses.
Has anyone else ever experienced this?
Any thoughts?
John N
Rockville
I’ll ask the easy question first on the dash lights, have you turned the headlight switch knob? If yes, it could be a bad switch or connection. Brake lights could be a mis-adjusted brake light switch at top of the pedal.
Dave The Sparky
Scrambling Across The Pond
Halifax
UK
Odd one but scanning through the wiring diagrams all those things that are not working points towards the turn signal switch or the fuse that feeds it. so i would suspect that either the long connector at the bottom of the steering column (think mine is black) that feeds the turn signal switch has been dislodged/needs looking at, or the turn signal switch has gone faulty.
Just double check that the fuse for that circuit hasn't actually gone but in a way that it still looks good, the pesky things have had me before pretending to be okay when they aren't! :o
mhinchliffe
W-S
My headlights would occasionally "flicker". I chased it back to a ground on the dash. I have factory wiring harness and I also took the advice on here and ran a dedicated ground from the dash panel itself to the (-) battery terminal. Use this as a good time to (-) the dash. Good luck and let us know.
sdsupilot
OKC
This happened on mine after replacing the turn signal switch. I didn’t fully connect it. I would check that before you pull too much hair out.
