Brake switch...what the...
Dansim
New member
Washington
UT
I have read the horror stories and still decided to go for it. Like that person in the horror movie and you say “don’t open that closet...” and they still do. What’s wrong with those people???
1. took out the front seat. Great suggestion.
2. I put the new switch on and before mounting it wanted to make sure it worked. Nothing.
3. replaced old dirty light bulbs. They work great. Turn signals work great.
4. go back to switch. Brand new. Why am I still not getting brake lights???
If anyone has an idea and want to shoot me your thoughts I would appreciate it.
tower210
Olathe
KS
Use a jumper across the terminals to see if that turns them on?
Dansim
New member
Washington
UT
I used a jumper wire across the connector terminals and still no lights. Looks like I need to continue to troubleshoot...
certifiablejeep
Definitley Certifiable
Bedford
NH
I can't remember the whole diagram, but is there a fuse in the way there that might be missing?
jammer1
Maple Hts.
Oh
Put a voltage meter on each of the wires (one at a time). One should have power, other goes to rear tail lights. If no power at any of the 2 wires, check fuse box fuses. If power in one wire, connect both wires then check power at tail light bulb. No power you have a broken wire or corroded connection. I would think you wouldn't have a ground problem if rest of tail lights work. Also a chance that both brake light filaments went bad. Don't have a wiring diagram at home to check. This is just the basic run of the wires.
FLCJ8
Palm Bay
FL
Here are some diagrams to go with the testing suggestions.
You may want to try testing voltage or jumping wires at the C125 connector.
Dansim
New member
Washington
UT
Holy Smokes ya'll are amazing! Thank you for all the help and diagrams! I will check and let you know. The fact that I don't have hazards or even a click makes me think it's a fuse or other issue. I'll report back. can't thank you all enough...
Randyzzz
Blown Budget
BENEFACTOR
Redmond
OR
You jumpered the switch and still no lights. Turn signals work but no hazards. My guess is the multifunction switch.
