Can not get the Oil gage to work,
One ton
Fredericksburg
Va
Got power, good ground, But how do you check to see if the sending unit is puting out with the engine runing? :banghead: I'm sure it is got oil presure it is a brand new motor and you can hear oil run back down in it. What should i try? I did replace the sending unit. :confused:
John N
Rockville
Got a spare guage you can try? I might have one somewhere, if you need it.
bobbysjeep
Charlotte
My jeep had the same issue. Installed a new sending unit on and oil pressure was back.
mulescj8
INSANE SCRAMBLER HACK
Tn
did you put teflon tape on the threads? if i remember right the sending units have to be grounded to the block to work, might check that
tower210
Olathe
KS
I struggled with this too. Replaced senders, they would work a couple weeks. Replaced with good looking mech gage for $5. Works great!
