- Rock Hill
- SC
Hey guys, question for you - I am about to pull the axle shafts out of the housing so I can put the mounting plate on for the disk brakes, as I am converting from drum to disks.
When I remove the bearing so I can remove the backing / mounting plate - I have the following questions:
(Assuming that the seals and bearings appear to be in good condition and that, aside from the axle sitting for 5 years, it had never been installed.)
1) is it possible and OK to reuse the outer seals (is like a plate with a rubber gasket around the center hole)?
2) is it possible and OK to reuse the bearings after removing them from the axle shaft, if they appear in good shape?
3) If I pull the axles, do I need to replace the Inner Seals too or just be careful when I'm putting the shafts back in?????
4) If I do need to replace all or some of these items, is there a difference between a regular axle shaft bearing and a Yukon "sealed bearing"???
5) Any advise or tricks for putting the axle bearings back on the shaft to the correct depth and without damaging them, if I am doing this in my driveway and have no bottle-press available?
If I need to replace these items to ensure they won't fail or (worse) leak, which is the best option?? They all look similar but are so different in price!
I'm worried that maybe just having these items mounted and then removing them will damage them in some way, such as stretch them, that will make it leak or fail if I do not replace with new components.
What is your experience and, if I have to buy new, where do you get this stuff?
Thanks, as always, Jeff
