- Carencro
- La
Ever since I purchased my 8 I have had thought the caster was off because; 1) the wheel doesn't return to center after turning 2) excessive wandering(all steering components new) and 3) 4" lift and no shims. I recently had it sitting on stands resting on the axles and did some checking. I checked the angle near the top ball joint and got -3.5. I have tried to find out what it should be and come up with different answers. What is the correct angle and is it ok to check it with it sitting on jack stands?
