Sounds cool… Here is an thread on JK
https://www.cj-8.com/threads/scrambler-on-a-jk-unlimited-frame-build.44502/
I did this frame on my Cj8
1981-1986 CJ8 Jeep Frame from ThrottleDownKustoms. Every product we make is hand fabricated in Moore, Montana, USA.
throttledownkustoms.com
A few thoughts from frame swap…
Axle 66.5” to 68” wide on JL vs 56” wide track CJ. will mean tire stick out 5” on each and depends on wheel back spacing.
Wheel selection is tricky because of backspacing needed to clear steering knuckle
Steering options get tricky on location of steering box.
Shock towers on JL front might require inner fender trim, not sure about rear.
Body mount on JL frame likely in wrong location and too wide as the body is about foot wider
Likely others have thoughts and anything is possible with imagination, time, skills and money. Look forward to seeing your next steps, well wishes
