Clock Installation Question
I have installed the clock to the dash, looks great :) , but i am unsure as to how the electrical connection works. i see on the fuse box there is a slot marked clock but it is an "L" shape. not sure if a fuse goes there or if the clock just plugs into it directly. there are two connectins under the dash by the steering column that fit the back of the clock, but only one has power with the ignition off and neither seem long enough to reach the clock :( . any help would be great.
thanks
bg2pres
Houston
Some clocks plug into the stereo harness and that goes back to the fuse panel.
On yours, just plug it into the panel and it should work fine.
