clutch master cylinder leak
redking11
Farmington
NM
How big/hard of a job is it to replace a clutch master cylinder? Any tips, tricks or things to watch out for?
Many Thanks
DirtyB
Crazy Cajun
Port Allen
LA
Bleeding the air out can be a pain in the butt. You'll need a friend with legs that don't get tired easily. You can also purchase some devices that help suck the air out. I used a clean glass jar and some black tubing and it worked great. Look on youtube and you'll find lots of instructions. It's basically the same as bleeding brakes.
Zodiac
Macomb
MO
You have a hydraulic clutch? Stock was linkage with a body-to-bell mounted bellcrank.
If it's anything like the YJ clutch master, it's a PITA. Internal slave cyl, funky bend in the line between master and slave, combine to make a real job. I often had an easier time pushing fluid up from the slave into the master using a syringe. I've also had passing luck drawing vacuum on the slave rather than trying to use pressure.
East Norriton
I had an 80 something CJ7 with a 4cyl that had a hydraulic clutch setup.
Schlap
Brentwood
TN
I’m curious how this worked out.
I have a leak in mine & would like to replace with a new one, if possible.
Belizeit
River Ridge
In 35 years I've rebuilt my clutch mc a couple of times and bought new a couple of times. Replaced the slave once on my T4. I would just buy new. Going to replace the T4 with a T176 and going all new with Hydraulic again. Just works well
