Coolant Temperature Ports
Is there a difference between the 2 ports on the intake in front of the carb?
Both of these ports had vacuum switches in them, so I am assuming either will work for my efi temperature sensor. Correct?
I am assuming, from reading this Blog that both ports are equal and it does not matter.
But, since the factory uses the first port for the computer controlled carb temperature sensor, that would be the better one to use.
I was debating plugging the other port or reinstalling the CTO valve. I think after reading the blog above, I’ll be reusing one of the 2 CTO valves that were originally on the engine. I’ll then reroute the vacuum hose to suite the new throttle body, vapor canister, and the other stuff that will not be removed.
Rosco1974
West Haven
UT
Dont see why/how they would be different. I would pick the cleaner install location and go.
