My transfer case (Dana300 was shot (splines worn etc) I ended up with an earlier one with the short output shaft, this is about 1" shorter than the later version.
Thoughts on using the stock driveshaft - which is now 1" too short? It is probably at the upper end of the length as installed with no weight (i put it on without the body in place).
Not planning on wheeling or anything, this is just a weekend toy.
