- richmond
- va
LT1 swap, doing away with the original charcoal canister and pollution stuff.
I have a rollover check valve.
Do I still need a liquid check valve? Mine was worn out and damaged.
I have the 15 gallon tank with the two vent hoses that originally went to the liquid check valve. I was thinking I would just tee those together from the tank and then run that hose to the DeLorean rollover check valve I have. Good or bad idea?
Let me know if you need any other info about my setup.
Thanks!
-Mike
Thanks!
-Mike
