- Richmond
- VA
Okay, now that I have you attention/interest, here we go...
Part I
I made a lot of measurements on all kinds of axles before I did the axle swap on my Scrambler (everyone jokes about the notebooks I keep on my Jeeps). One of these days I need to post this information. Bottom line, I believe the WT FSJ Dana 44 is the best front axle for a Scrambler if you are going to stay spring under and want to run tires larger than 31". And, here comes the controversial part, I also believe it is a mistake to use a narrowed Wagoneer axle. These conclusions/opinions are based on my many measurements, my knowledge of Jeeps (limited as it may be), observations on my completed axle swap and noting what other Jeepers have done. I am not asking to debate this issue, but I do offer the following information for those who are curious about how I came to these conclusions.
All CJ's, NT FSJ's (Wagoneer and NT Cherokee) and WT FSJ's (WT Cherokee Chief and J trucks) had/have wider front axles than rear axles. So do many other vehicles, particularly four wheel drive vehicles. Why? I believe the answer is turning radius and tire size. Here are the Jeep "tread widths" Front/Rear from the 1983 Jeep Product Information and Data Book. Also included in parentheses is information from the 1981 book covering the NT Scrambler. These measurements are in inches:
CJ5 52.4/50.5
CJ7 55.8/55.1
CJ8 55.8/55.1 (81 NT's were 51.5/50)
Wagoneer 59.4/57.8
WT Cherokee 65.3/62.3
J10 65.4/64.9 (wide wheel option)
J20 64.6/65.9 (wide wheel option)
The AMC FSJ Wagoneer, NT Cherokee and WT Cherokee have the same frame and body. There are only minor modifications behind the front door to make 2-door or 4-door version. The WT Cherokee (only a 2-door) also had a flare built into the fenders like the J trucks to cover the wider axles. As you can see from the above data WT Cherokee axles were 5”-6” wider than Wagoneer front axles. AMC used the same axle on a WT Cherokee as the J10. Other than axle shaft and tube width all other axle components are interchangeable between the NT and WT. I believe this is also true among the NT and WT CJ’s.
Why did AMC put a wider axle on the Chiefs and J trucks? Answer, because the Chief was a more "sporty" 2-door with larger/taller tires and wider rims (the trucks also had taller tires than the NT’s). This enabled the vehicles to maintain maneuverability (turning radius). Standard wheels on a Wagoneer were 15 x 7” with 235/75/15 tires (28”-29” tall). Standard wheels and tires on a WT Cherokee were 15 x 8” with 31x10.50x15 tires. In order to run a 2”-3” taller tire without further adjusting the steering stops the wheel mounting surface needed to move further away from the springs and frame.
Among my Jeeps I have both NT FSJ (74 Wagoneer Custom) and WT FSJ (79 Cherokee Chief). With stock wheels/tires the Wagoneer had a 37.7’ turning radius and WT Cherokee 39.4. However, when I tried to run larger tires on the Wagoneer (33x12.50x15 on 8” rims) I had to either adjust the turning stops (reducing my turning radius) to keep the tires out of my springs (vehicle has the appropriate lift) or buy rims with less backspacing than stock (FSJ backspacing is 3.75”. A 10” rim on a Wagoneer (NT FSJ) can really be challenging.
On the other hand, the Cherokee runs 35x12.50 tires on 10” rims with no issues. Why don’t I have the same problem with the Cherokee as the Wagoneer? Answer: the wheel mounting surface on the WT axle is further away from the springs. I can actually go to 4” backspacing without worrying about the springs or frame. This is more important on the front axle because the front axle wheels move toward the springs when you turn. As a result, the difference in turning radius between my “adjusted” Wagoneer and Cherokee running large tires is significant.
Part I
CJ5 52.4/50.5
CJ7 55.8/55.1
Wagoneer 59.4/57.8
