Well my Steering ram was attached to mt Passenger side spring-plate, not what I wanted but thats how it ended up, it worked fine for quite a while but now it's bad. the stud bolts that go into the diff housing are both broken off. My extraction did not go well. I think I'll be drilling them out larger, then tapping for new beefy bolts. Hopefully that will hold me over until the coil-overs are in the picture. First order of business now however is to get my tow rig running again, I need to replace the oil pump, unfortunately to get to it I have to remove the 460 from the truck, then I can change it out. Lame but needed. Then I intend to go wheeling at Reiter (our local wheelin area) and leave a sign in the window "For sale $2k OBO" I figure if I get 1-1.5k I'll be able to buy a trailer and use my friends Furd Diesel for a while.
Anyways heres a picture I found, my scanner here at work is awesome, unfortunately I don't scan photos often so the colors came out funky, I Doctored it up a bit in Photoshop so if it looks a bit cartoonish thats why.....
This is a pic from a camping trip I took to the Columbia River Gorge around 1996-97, 33" BFG Ats, 3:73:1 gears, T-18, 258 (Clifford intake, header, 300 CFM 1 bbl Holley Carb)
