RandyLL
1 Long CJ
- Highland
- IL
At highway speeds, my engine seems to cut out completely then comes back. Intermittantly and some days worse than others. It has newer fuel tank, new fuel lines, filter, etc. I've swapped ignition module, coil, wires, cap, rotor, starter relay (I had one short out internally), etc. I know I've got some carb issues, because it also dies (sometimes) when I come to a stop. My question is, could there be an issue with the ignition switch (key). Does the igni.mod/coil power actually run through the switch? I was thinking I could run some sort of bypass wire to check this theory.
I do plan on rebuilding the carb and I am also considering an HEI system.
