Fan to radiator clearance?
Super 8
Bozeman
MT
Working on my 1985 bone stock (258/T5) CJ8. Replaced the radiator and only have about 3/16 inch between the radiator and fan clutch. My 1983 CJ has about 1/2 inch of clearance between the radiator and fan clutch. Both these distances seem too close. Any other stock CJ8 folks that can chime in? What kind of distances do you have?
gr8dain
Old and Slow
Ashburn
I have always had the fan clutch and the radiator. I gained about 1/2” by moving the radiator toward the grill. I slid the radiator mounting flanges INSIDE the radiator. I slid the radiator in through the bottom of the core support/grill. I also had to flip the threaded clips around and screw the bolts in from the front. A little bit of a pain, but doable. Let me know if you want to see pics. I can get some for you.
Before I did this, I had a motor mount go bad and the fan bore a few holes in the radiator. Not fun. I used an electric fan for a while, but hated it and went back to a clutch fan.
jak inc
I H8 RUST!
Merton
WI
The Summit Racing™ Classic OEM Radiators SUM-382007 (2 Row) is the only radiator that I have found that fits the fan clutch and shroud perfectly. I don't believe 3/16" is going to be enough clearance.
gr8dain
Old and Slow
Ashburn
Here are pics of my clearance AFTER moving the radiator inside of the grill. It is a 2 row aluminum radiator from Champion.
Alaskan Postal nutjob
FORUM MANAGER
Another victim of a fan getting into a radiator and I agree that you're too close.
(I did the dual Ford Contour electric fans now and love it, I just want to add a programmable variable frequency controller because they cool TOO well.)
gr8dain
Old and Slow
Ashburn
I had the contour fans at one point as well. I think I had a poor controller though as I blew 40 amp fuses every couple of months. And when it died, it was off and I over heated. I would rather have my fan on by default. So when I put the 4.0 in, I went back to a clutch fan. I considered removing the clutch to gain more clearance but decided against it. For now.
FORUM MANAGER
Not set up right. That’s the benefit of the two fans. Wire them separately to dedicated relays/fuses off one temp switch signal and you’re redundant. With an AL radiator, one works to keep it from overheating at low speeds/trail and isn’t even needed at speed.
I also have a hard wired bypass in place coiled up to plug in should something go wrong to just run them non-stop.
gr8dain
Old and Slow
Ashburn
I don’t disagree with you regarding how it was set up. I did it per the instructions. I am not smart enough with wiring to have gone rogue and made it better.
gr8dain
Old and Slow
Ashburn
Update…. I need to rethink my setup. I am thinking of going with a fan without a clutch. While wheeling this weekend, the twisting caused my radiator and fan to become lovers. Need a new radiator now.
Did you break a motor mount, or did the grill/radiator fall backward somehow?
HighSierra CJ
Scrambler Enthusiast
Ducor
Ca
I’ve had clearance issues with aftermarket 3 core radiators. I ended up taking the stock OEM 2 core radiator and having it re-built as a 3 core. I made sure that the radiator shop maintained the same position/angle when reinstalling the mounting flanges.
gr8dain
Old and Slow
Ashburn
We did a quick test of revving the motor and the engine seemed pretty solid. So it does not appear to be broken motor mounts, but I will investigate more now that it is home
