- Goodyear
- AZ
I just got done upgrading from manual to power steering. Put in a heavy duty steering gear box (AGR) and a heavy duty gear box mount (Sam's Offroad HD CJ bracket). Of course had to replace the lower steering shaft as the splines are of different size than what is found on the manual system. I am using a stock pump and new hoses from 4WD.
I ran into fit problems where the hoses attach to the gear box so I cut out some of the cross member to keep the metal hose ends from rubbing.
[/URL][/IMG]
Then I put the radiator in and now found the radiator outlet right above the PS hoses. Hardly any room to squeeze your finger between them. The PS hoses run along side the lower steering shaft and look like a potential rub problem.
[/URL][/IMG]
This is a 3-core radiator I was using with my manual steering set up. So is there differences radiators for PS verses manual steering applications on CJ-8?
