Thanks - I checked out inline tubes web site & did not see anything related to fuel tank. Everything kept defaulting to brake lines.In-line-tube has them or you can bend them up yourself. Fuel supply line, fuel return line, and vent line.
Rubber lines between the tank and the filler neck or the rubber lines between the tank and the hard feed / return lines or the hard lines?
The two larger lines at the fill.Rubber lines between the tank and the filler neck or the rubber lines between the tank and the hard feed / return lines or the hard lines?
In line has the 3 lines from the tank and the lines from the fuel pump to carb.Thanks - I checked out inline tubes web site & did not see anything related to fuel tank. Everything kept defaulting to brake lines.
Buying individual hoses might be the way to go?
Thank you.
Got my fuel lines from MTSCompany yesterday - appreciate the help, good company to deal with.
