Hard top texture
craveman85
Dolgeville
ny
Anyone know how to put the texture back in a hard top without spraying bed liner on it? How bad do they look without the texture on them?
jeepinjosh
pell city
al
i repainted mine with a small roller to keep as much texture as possible. it worked for the most part. I also didn't sand it at all...just wiped down with lacquer rag.
i considered using one of those deck resurfacing kit, but was scared i'd get too much texture and lose its original look.
craveman85
Dolgeville
ny
Have any pictures of it maybe at 20' and a close up? I asked some local fiberglass places but they had no clue. I wonder if I could figure out what ingredient makes wrinkle finish paint wrinkle and test it out.
CBRogers
Perpetual Parts Collector
Yorktown
Va
Get the spray cans of Trunk Paint. It has a splatter nozzle that will put a texture on it. Then go over with a fine mist of a good quality of paint. Krylon has a nice nozzle for laying down the paint. Also Eastwoods new 2 part paint have a very big spray pattern.
If you have a decent spray gun use a large tip designed for Primer. Something in the 1.8-2.3mm size. Turn the air pressure way down. like 10-15 psi and the fluid flow all the way up. That will spit really large globs. Use a thicker 2 part paint with very little reducer. That should give you a pretty good pattern.
Just experiment with air pressure and fluid thickness to get the pattern you like.
Carl
DeLuke
Dallas
Prepping to tackle a top texture and re-paint. Any more thoughts or recommendations on this texture topic? Has anyone used other texture products (like wall textures??) and then sprayed over them with regular paint?
CBRogers - What type of spray Trunk Paint do you recommend?
Thanks,
jak inc
I H8 RUST!
Merton
WI
el Coat
Here is the product I used for texture... it worked excellent.
3M Rocker Panel Coating
http://3mcollision.com/3m-rocker-panel-coating-08889.html
I topped it with 1 coat rustoleum fiberglass topside primer and 2 coats rustoleum fiberglass topside paint, all with a foam roller.
I reason I didn't try the trunk paint was that the different colors and textures in the can are achieved with a combination of oil and water based paints so they stay separate. I was worried that the oil based primer would start to dissolve the texture. Hope this helps.
