What year is it? Headlamp fuses should be hot all the time. You could test-light both sides of each fuse to see if one is hot one side and not on the other. If not a fuse, then possibly the headlamp switch.First , the best info I got was from your forum on my CJ7. My CJ7 Headlights, taillights, parking lights don't work. Brake and directions do work. I cannot locate the fuse for this circuit after many web site searches. Really would like your help.
As Randy stated, a test light is your friend.First , the best info I got was from your forum on my CJ7. My CJ7 Headlights, taillights, parking lights don't work. Brake and directions do work. I cannot locate the fuse for this circuit after many web site searches. Really would like your help.
There should be a 20a fuse labeled "Park /Tail" for the park/tail lights.
There is a fusible link in the feed going to the light switch, there is also a circuit breaker in the switch for the headlights.
Also a defective floor mounted dimmer switch/wiring can cause the headlights not to work.
As you can see on the schematic the headlight switch is common to both systems, however you could easily have two separate problems, so don't jump to changing the switch without testing.
A series of simple tests from source to load will help pinpoint the problem(s).
If all the power checks test out, (using a known good ground), it's time to check grounds at the lights.
Thanks for you reply.As Randy stated, a test light is your friend. There should be a 20a fuse labeled "Park /Tail" for the park/tail lights. There is a fusible link in the feed going to the light switch, there is also a circuit breaker in the switch for the headlights. Also a defective floor mounted dimmer switch/wiring can cause the headlights not to work. As you can see on the schematic the headlight switch is common to both systems, however you could easily have two separate problems, so don't jump to changing the switch without testing. A series of simple tests from source to load will help pinpoint the problem(s). If all the power checks test out, (using a known good ground), it's time to check grounds at the lights. View attachment 95978
Once the knob assembly is all the way in, push down partially on the release while wiggling the switch in and out a few times. I’ve had the retainer get cocked a few times and the maneuver I described solved the problem.Thanks for you reply.
I cannot locate a fuse. I checked all the fuses I could locate independent of circuit. All good.
Where is the fusible link?
I replaced broken dimmer switch and termination. ($18)
I replaced the light switch ($17). The knob doesn't stay in well. I cut open the old switch to see how it holds in place. One has to pull the extended switch opposite. the release button. Rather poor design. Still pulls completely out sometimes.
CJ's are notorious for bad electrical ground issues as they are body grounded & also prone to corrosionThanks for your help. Still working on it. No success yet. Head lights, parking lights and turn signals not functioning.
