Heater and vent
splogue
Norfolk
Va
It seems to be a theme, my heat does not work.
When I pull the VENT/HEAT KNOB half way out (heat) nothing behind the dash moves, except a little spring. When I pull it all the way out it is ard to get past the half way mark then ok. The metal rod and heater cable then move. BUT going back to off it is hard again. The heater vent door moves only a half an inch in either direction.
Here are my questions when moving to HEAT, what cable should move?
is it normally hard to go from heat to vent and back to off?
If the sheathing is broke will that affect the cable movement? It is broke right past th adjustment turnbuckle.
Sean
