Help Finding Sport Cage Mounts
breckwrecking
Narrow Tracker
Kittery
ME
I started ripping apart the interior to prep and repaint for rust control. I found out one of the forward sport cage mounts was rusted through. Does anybody know where I can find a replacement for this or do I have to scavenge old cjs?
certifiablejeep
Definitley Certifiable
Bedford
NH
Do you have a picture of what you are referring to? Sport cages were normally on YJ's... so I am curious as to which mount you are referring to.
breckwrecking
Narrow Tracker
Kittery
ME
I'll take a picture when I get home later. Just the mount for the rollbar that has the square nuts welded to it. I know some people refer to the bar as a sport cage vs roll bar.
breckwrecking
Narrow Tracker
Kittery
ME
The one under the tub is the one I'm looking for. Thanks for that link. I figured one of the major jeep suppliers would have it but I didnt know the actual name of the bracket.
certifiablejeep
Bedford
NH
Yeah, those aren't remade... not enough market for them I would imagine.
If EVERY single scrambler needed a replacement one of those, you are only looking at 50,000+ pieces... and the odds are probably only 10% need them.
Not sure if I have just the one, I can check.
breckwrecking
Narrow Tracker
Kittery
ME
That's true. Let me know if you happen to find one, I can make the drive out to see you. I probably could use a few other parts as well.
certifiablejeep
Bedford
NH
I found this...
It would need some work on the side to replace that metal, but the rest is decent.
