Help...New fuel tank is different size than original
Loyalpoke
Stillwater
ok
I am about to put the tub back on the frame. I wanted to replace the old poly tank that had multiple epoxy repairs. I ordered a Omix or Crown from Morris, 15 gal steel, to fit my Scrambler. The old poly tank was held in by hoop cradles. The new tank has flanges that I assumed would attach to frame and cross members but is is not even close. How is the metal tank supposed to attach?
East Norriton
If it was a factory tank it was bigger than the 15 gallon steel replacement you bought. Nobody makes a factory poly tank replacement.
Loyalpoke
Stillwater
ok
Thanks SDSUPilot, I think that is what I missed. I'll get one. Will the hold down straps for the poly tank work?
