Help with BDS YJ spring conversions
jveesart
New member
Shallowater
I’m piecing my lift together using M.O.R.E 4”shackles and BDS 3.5” YJ springs. What I’m running into is the shackles won’t clear the spring eye. I doubled checked part number (4351) and they are correct. I feel like they might be marked wrong? Any help is appreciated image.jpg image.jpg image.jpg
My shackles have offset center bars but I think once there is a load on the springs the mil wrap leaf moves down giving more clearance. 596F61E3-5709-44DD-91B5-9FAA16EDA7C8.jpeg
I used BDS boomerang shackles on my green Scrambler that has the BDS YJ conversion. I don't think a standard height shackle, or a centered center bar, will work?
Rosco1974
West Haven
UT
Thought: Your wraps looks bent/oblonged and taking up too much space. Randyzzz looks round and tight.
AK-RWC
south central
AK
OEM YJ shackles don't have that center piece. So, in a factory-swapped application, these springs would be just fine.
You can probably drop the center bolt/spacer from your aftermarket shackle and still be safe.
