Help with bracing tub for acid dip and rotisserie
CJocho
CHICAGO
Il
Hi everyone,
I'm looking for some guidance on how to brace my tub for acid dipping, and then on to a rotisserie for patch repairs and paint. Currently the tub has the roll bar off but the bulk head installed (I'm pretty sure that's what it is called. Either way it's the piece that sits between the rear of the front seats and the roll bar). I would like to brace it so I can remove the bulk head and not worry about the tub warping when it gets dipped and put on the rotisserie. That being said, the bed has large rust holes so I'm pretty worried about moving this thing further than a few feet at a time. Any pictures or detailed writeups on bracing for rigidity and bracing for HF engine stand rotisserie hack would be much appreciated. Lastly, I have a welder and just enough knowledge on how to use it to be dangerous. Thanks for your help.
Belizeit
River Ridge
Just do a search in the search forums area under rotisserie, i just did and found a few examples in a couple of minutes, with pictures.
