Help with cross member angle bracket. What's it for?
gpassida
Silver Member
Redding
Ca
I am in the process of reassembling my Scrambler and wanted to paint some lose parts.
I can't find this angle bracket that was screwed into the cross member that the rear side of the fuel tank bolts to.
I can make one easy enough but what is it for? All my pics show it bolted on but not doing much?
Thanks!
George
Randyzzz
Blown Budget
BENEFACTOR
Redmond
OR
It keeps the sharp edge of the sheet metal away from the tank in case of a rear end collision.
Dave The Sparky
Rebuilding my CJ8 very,very slowly...
Member
Halifax
UK
Side shot to assist with correct shape as i had the piece and was trying to work out where it came from earlier in the year.....
gpassida
Silver Member
Redding
Ca
Thank you! Makes sense! Especially for the plastic stock tank.
Although my tank is a TrailQuest steel 23 gal tank. I just stripped off the paint/rust to give it some fresh primer/paint.
Randyzzz
Blown Budget
BENEFACTOR
Redmond
OR
Those were great tanks. Especially for fuel injection conversions. Too bad they stopped making them.
Belizeit
River Ridge
La
I had one that looked just like that that I think was 21-22 gallons. My only problem with it was it hung to low, especially in deep ruts.
gpassida
Silver Member
Redding
Ca
This one is 23 gallons. Love it. It has the steel skid plate welded on. With the SOA and 35's it has good clearance. Has taken a beating on the Rubicon and Moab over the years.
I have a 1" body lift. I will probably cut the mounting tabs off and re-weld them 1" lower. That would tuck it up 1" higher for a little more clearance.
