High Output Alternator recommendations?
MomoJeep
Seattle
WA
Anyone recommend an Alternator with higher output than the oem replacement?
Are they typically in stock at parts stores, or do they have to be special ordered?
Chamba
Not obsessed: focused.
Vero Beach
I had a Mean Green in my Land Cruiser for years without issue. My Jeep has a 351W and I was able to get a 125 amp at the Napa.
I didn't check whether they had one for a 258, but I know nothing was offered for the Toyota 2F by Napa or the others.
That was the only reason I got the Mean Green.
Post #331:
I used an off the shelf NAPA alternator, 93 amp, bolted right into the OEM V-belt brackets. I did have to "re-clock" the alternator, other then that, simple bolt in swap.
HighSierra CJ
Scrambler Enthusiast
Ducor
Ca
I’ve been running a mean green for the past 8 years. No problems
MomoJeep
Seattle
WA
I can get one at Napa, 85Amp, for around $85. Or A mean green, 120Amp for around $300+. Hmmmm
Is 85 Amp enough to just run 2 fog and 2 driving lights (non-LED). ?
East Norriton
Check out Powermaster. Cheaper than Mean Green. I have a new alternator in my basement that is a corvette replacement. Suppose to be bolt in( might need to be clocked though). Brand and part # will do no good since I bought it 25+ years ago and # doesn't pull anything up when goggle searching for it. I bought in back in the days of "Jeep-L" (anybody else remember that) long before there was any type of useful internet searches and stuff.
Silver Member
What wattage lights. You might be just fine with the stock alternator.
MomoJeep
Seattle
WA
Does anyone know if the stock 258 alternators are compatible with the MOPAR (94'Wrangler) MPI Fuel Injection conversion I have? I would assume it wouldn't make a difference, but I've heard people say otherwise..(?)
HighSierra CJ
Ducor
Ca
I have the Mopar MPI kit on two of my Scrambler‘s. I didn’t have to do any modifications when it came to the alternators. Still running the factory style alternators.
Chamba
Vero Beach
I put LED H4 headlight globes in my Hella H4s and it made a huge difference in the draw at night. Now with heater, wipers and lights on at night my lights don't brighten noticeably when I rev the engine. They did before. ( mind you, i have no radio in my 8 because that would drown out the music of my 351W).
85 amps should be more than enough for a vehicle like ours which has no real mod-cons to speak off. Yes, winching may draw down your battery a bit, but how often do you plan to winch for 30 minutes and then shut the engine right off before the battery can recharge?
If you decide to add air con, power windows, seat heaters, heated steering wheel and a 12' screen radio with amps and doof-doof speakers, then you'll need a Mean Green.... and thick skin to ignore all the laughing.
MomoJeep
Seattle
WA
Exactly!
I got the 85Amp today at Napa. It should be enough to power my girlfriend's vibrating seat and glow-in-the-dark oh-shit-bar! lol
MomoJeep
Seattle
WA
Update! The 85Amp doesn't fit. I think it was for air-conditioned models. But I did get a 78Amp. Works very well.
