Hydraulic clutch slave
Trevor Davidson
Kitchener
On
Good evening ,
I have a 258 and T176 in my 83 scrambler and
I was wondering if any members have done a Hydraulic clutch swap using Novak slave cylinder .
If so what Novak slave did you use 3/4bore
Or 7/8 bore.
I am using a stock iron duke master cylinder with what I think has 13/16 bore.
Thanks
Ron84cj
Engine nerd
West Bend
WI
Yes, the stock clutch master is 13/16" bore. The factory slave is 7/8" bore. Does the Novak setup use the factory clutch fork? If it's longer or shorter than stock that changes things.
Trevor Davidson
Kitchener
On
I got the bellhousing and clutch fork from Novak also,so I would assume it’s the same as stock.
Thanks
Ron84cj
Engine nerd
West Bend
WI
Wow. I just looked this up on their sight. Maybe I'm just stupid but they kind of confused me. If it was me, I would get the 3/4" bore. Then you can easily switch to a different ratio if needed. The CJ master is 13/16", the YJ is 11/16". Or you could go right in the middle and get a 3/4" bore Wilwood master like mine.
